replacing axle seals - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-05-2014, 01:00 PM Thread Starter
alright so my front axle on the driverside is making quite the mess with fluid so i was going to do the axle seals.
I can tell the outter axle seal is bad or possibly gone because the fluid is just running out so i want to replace both outter and the inner seals.
ive done some research and everyone says its a farley straight forward job to replace just have to remove the hole carrier out of the axle. Ive never done something like that but seems straight forward but a couple of my buddie said that most of those diff's need to be shimmed up when installing and i cant find anything about doing this anywhere for the fords.
just curious if this is true or not. if it doesnt need shimmed ill probably tackle this job on my own.
egobuster1 is offline
post #2 of 6 Old 07-05-2014, 01:31 PM
ZMANN's Avatar
Quoted: 1464 Post(s)
you take it out and don't mix up anything then you don't need to re set it up
read up there ares some tricks to doing this and updated seals
suggest looking at the condition u joints and / balljoints / knuckle seals / unit bearings etc
We Miss you Ronnie
ZMANN is offline
post #3 of 6 Old 07-05-2014, 07:40 PM
Quoted: 57 Post(s)
Completely agree with ZMANN. If you've never done ball joints or front axle ujoints, now would be a good time.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #4 of 6 Old 07-06-2014, 02:14 PM Thread Starter
alright I've done a decent amount of research and saw where theres a special tool needed to do it and that some people have made there own tool and such. just wasn't sure about how hard it was to actually remove the carrier and reinstall. seems pretty straight forward if it goes back in just how it came out.
i also was thinking about doing the ball joint and u-joints and sway bar end links and busing.
post #5 of 6 Old 07-23-2014, 03:42 AM
if you are gonna have it all apart replace what you can while its open
jherbie28 is offline
post #6 of 6 Old 07-23-2014, 07:50 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
The outer seal is just a dust seal and often the lip just become the free floating band on the knuckle. However, as you indicated you have fluid seeping out and that is from the inner seal and that should be fixed. As suggested, once you have it out it just makes sense to check or even change out the ball-joints, seals and to a lesser extent the bearings.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
