Did I get the right axle seals for my 05 350 SRW? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-26-2014, 05:36 AM Thread Starter
Rtd
I picked up this truck a few weeks ago and I've started picking away at all of the little issues it needs repaired, today I was working on leaking real axle seals. I know that I have 10.5" Sterling axle however the Napa store only showed 1 listing for the F350, I took my chances hopeing I got the right ones but I'm really not sure how to tell, can anyone help me?
Rtd is offline
post #2 of 5 Old 06-26-2014, 05:39 AM Thread Starter
Rtd
Pic 2, for some reason I can't seem to load multiple pics in one post.
Rtd is offline
post #3 of 5 Old 06-26-2014, 05:40 AM Thread Starter
Rtd
Pic of box with # napa and skf # 29425
Rtd is offline
post #4 of 5 Old 06-28-2014, 11:01 PM
F350Powerstroker's Avatar
Well I bought Motorcraft when I replaced mine so can't help you with part numbers, but yes they look correct if that helps. By the way do you have the special socket for the axle nut? It's not so much important removing but putting back together. You need to torque the nut to spec and then turn back 3 clicks or so (depending on new or reusing bearings). You'll most likely need a puller to remove the hubs my sealers were seized to the axle spindle. Also if you haven't started yet just to give you a heads up check your backing plates. Mine were rotted out where the parking brake alignment pins go. So I had to replace them. Just good to know before you tear into it hopefully helps!
~1973 F250 Highboy
~2003 F350 Super Duty XLT FX4 6.0 Powerstroke
4.56 Yukon Gears,Detroit Locker,37x13.5x17 Interco Super Swamper M16,8in Custom Lift,Bilstein 5125 Custom Valved Shocks (Triple Front/Dual Rear),Fabtech Dual Rear Shock Kit/Traction Bars,ARP Head Studs, Sinister Headers/Y Pipe/Regulated Return,175 cc Injectors,Edge Juice Platinum with Attitude,SCT Tunes,Snow Performance Stage 3 Water Methanol Injection,FASS 150/180,Banks Techni-cooler System,Fluidampr,4in Straight Pipes.
F350Powerstroker is offline
post #5 of 5 Old 06-29-2014, 10:26 AM Thread Starter
Rtd
That helps a lot, I do have the socket, good call on the backing plates, they were rusted, I only noticed as I was about to start putting it back together, so I ordered a set. This is not my daily driver so sitting on stands for a week is no big deal, I might as well wait and do it right.
Rtd is offline
