2003 rear diff fluid ? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-20-2014, 07:06 PM Thread Starter
So going to change my fluids in the front and rear diff. Now what is the best gear oil for it and how much friction modifer to use in the rear.Read the foward needs none is that correct? Planning to probally use amsoil.
03 f-250
blue spring
4inch turbo back exhaust
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
155/stock holder diesel
tatertot is offline
post #2 of 4 Old 06-20-2014, 07:18 PM
ZMANN's Avatar
Quoted: 1346 Post(s)
if u use amsoil u won't likley need modifier
if u have some limited slip chatter around corners then u need the Amsoil LS additive
make sure u use the proper weight front and rear no matter what brand u use
forward is an open diff it needs no additive
We Miss you Ronnie
ZMANN is offline
post #3 of 4 Old 06-20-2014, 07:28 PM Thread Starter
Thanks zman thats what I was looking for going to use 75-140 rear and 75-90 for the front just getting ready for the move to alaska
tatertot is offline
post #4 of 4 Old 06-28-2014, 10:46 PM
F350Powerstroker's Avatar
Go with AMSOIL Sever Gear. Great Stuff! I run 75-140 in front and rear. I would burn up Motorcraft gear oil way happier since I switched to Severe Gear.
And ZMANN is spot on [QUOTE=ZMANN;9439153]if u use amsoil u won't likley need modifier
~1973 F250 Highboy
~2003 F350 Super Duty XLT FX4 6.0 Powerstroke
4.56 Yukon Gears,Detroit Locker,37x13.5x17 Interco Super Swamper M16,8in Custom Lift,Bilstein 5125 Custom Valved Shocks (Triple Front/Dual Rear),Fabtech Dual Rear Shock Kit/Traction Bars,ARP Head Studs, Sinister Headers/Y Pipe/Regulated Return,175 cc Injectors,Edge Juice Platinum with Attitude,SCT Tunes,Snow Performance Stage 3 Water Methanol Injection,FASS 150/180,Banks Techni-cooler System,Fluidampr,4in Straight Pipes.
F350Powerstroker is offline
The Following User Says Thank You to F350Powerstroker For This Useful Post:
Corey@CNCFAB (06-29-2014)
