Pinyon/caster way high! - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 23 Old 06-10-2014, 06:46 PM Thread Starter
broncomitch's Avatar
I'm installing 06 axles and suspension on my 99.
I got the chassis as a roller and it had a 6" lift kit on it..I sold the lift cus I'm going stock with a leveling kit.
I'm installing the axle and right away I see a problem...
Any thoughts?
Cus I thought the caster can't be adjusted...everything is stock apart from the obvious...
Please help, I dieing to get my truck back on the road!
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #2 of 23 Old 06-10-2014, 06:56 PM
ZMANN's Avatar
Quoted: 1344 Post(s)
looks like the radius arms need a drop?
but if your going leveling kit it shouldn't
lets see the radius arm mounts ??
We Miss you Ronnie
ZMANN is online now
post #3 of 23 Old 06-10-2014, 06:58 PM Thread Starter
Everything is stock tho...coils, brackets, arms, buckets.
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #4 of 23 Old 06-10-2014, 07:00 PM Thread Starter
Give me a min
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #5 of 23 Old 06-10-2014, 07:04 PM
ZMANN's Avatar
thats a stock spring and stock lower mount ?
We Miss you Ronnie
ZMANN is online now
post #6 of 23 Old 06-10-2014, 07:10 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Is the full weight of the truck on the axle? If not I would put jack stands just under the axle and set the truck back down on it and see where it is. Then you can decide where to go from there. Post more pics if you put the weight of the truck on the springs.
ZMANN likes this.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #7 of 23 Old 06-10-2014, 07:19 PM Thread Starter
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #8 of 23 Old 06-10-2014, 07:20 PM Thread Starter
I can't put weight on it cus the springs won't even seat in the pads...
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #9 of 23 Old 06-10-2014, 07:25 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Have you put a jack under the axle and jacked up and see if they will seat with some pressure. If that don't work. Maybe seat the spring on the axle first, then try to seat the coil in the bucket
01 f-250, Standard
post #10 of 23 Old 06-10-2014, 07:28 PM Thread Starter
Tried that.. The pads sit to far forward I can't put em in the bucket and I'm right back to square one..
I shouldn't be having this problem, I was thinking mybe my arms are upside down but they measured the same from eye to eye
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
