My truck scares me - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 11 Old 05-28-2014, 02:24 PM Thread Starter
ps_lane01's Avatar
Quoted: 2 Post(s)
My truck scares me
My truck has been locking up and will randomly start turning left or right. Sometime it will pull left/right constantly, other times it will just act like one wheel is headed in a different direction for a quick second. Both sides of the inner tie rod- pitman and the connecting arm sides are completely shot so i know they need to be replaced but was wondering if this could be something else causing these problems before I tear into her.
Thanks guys!
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #2 of 11 Old 05-28-2014, 02:34 PM
Term3's Avatar
I had a ball joint seize up that gave my very strange strong pulling to one side depending on which way I came out of a turn.
STANGMAN893 likes this.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 11 Old 05-28-2014, 03:17 PM Thread Starter
ps_lane01's Avatar
Quoted: 2 Post(s)
My truck scares me
Thanks term3 i know the ball joints havent been replaced in over 85k so its probs time to do them too... I engaged the locking hubs and found the wheels wont spin when the driver side u joint is in a certain position.. Straighten the wheels out and the wheels will spin.. Doesnt explain the random vereing off to the left or right when driving straight, tho.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #4 of 11 Old 05-28-2014, 03:18 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
do you have a caliper thats holding on/sticking?
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #5 of 11 Old 05-28-2014, 03:29 PM Thread Starter
ps_lane01's Avatar
Quoted: 2 Post(s)
I thought that too because it will act funny when braking or going through turns . But the symptoms are kind of random and in my experience when a caliper sticks it typically sticks consistently or after hard brakes or lots of driving, correct? Whereas, this is more of a jolt or quick push to one side.
I will definetly inspect the brakes to rule them out.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #6 of 11 Old 05-28-2014, 07:45 PM
your front axle u-joints are bad. mine did this last summer when i was going to milwaukee - drove 700 miles like that - new u joints fixed it. about 700 bucks at a shop
2006 F-250 SUPERDUTY 6.0 EXT CAB LONG BOX
EDGE CTS, MBRP 4IN TB, SCT, IPR COOLANT FILTER
12SCREWS is offline
post #7 of 11 Old 05-28-2014, 08:17 PM Thread Starter
ps_lane01's Avatar
Quoted: 2 Post(s)
Thanks 12screws and everyone else! Looks like i will be ordering up u joints, ball joints, and tie rods. That should make for a fun weekend project.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #8 of 11 Old 05-31-2014, 11:33 PM
Definite u joints. Just went through this
03 f350 is offline
post #9 of 11 Old 05-31-2014, 11:42 PM
Rodslinger's B1TCH
since you'll have everything apart anyway, rebuilt calipers are pretty cheap so i would replace them too along with pads and replace/resurface the rotors.
i think rebuilt calipers for mine were $75 each plus $100 core charge
steve604 is offline
post #10 of 11 Old 06-08-2014, 09:49 AM Thread Starter
ps_lane01's Avatar
Quoted: 2 Post(s)
Ball joints need a press tool, correct? Will a parts store have a rental or is there a easy tip for this? What about the hub seal or axle tube seal- need a press or do i even have to replace these? My hubs and needle bearings/ seal should be in good condition since they were replaced a few months ago.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
