Hot rear brake rotor - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-26-2014, 07:14 PM Thread Starter
I've noticed the last few times I drove somewhere I smelled what seemed like hot brakes or burning rubber. I knew it couldn't be the brakes. Then this evening I happened to walk past the rear passenger wheel after a 60mile trip and felt heat coming from it I reached in and touched the rotor and it nearly burned my hand. Could it be a bad wheel bearing?
wingsandwalleyes is offline
post #2 of 12 Old 05-26-2014, 07:16 PM
Hate stupid people
CloverLeafFarm's Avatar
Quoted: 140 Post(s)
Stuck caliper slide pin, hung up and kept brake tight
Illiana Strokers DICtator
EFI Live tuned 6.7
CloverLeafFarm is offline
post #3 of 12 Old 05-26-2014, 07:17 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Your brake caliper is probably hanging up and is causing the brakes to drag. Very common on Super Dutys.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 12 Old 05-26-2014, 07:17 PM
Quoted: 8 Post(s)
What he said!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 12 Old 05-26-2014, 07:21 PM Thread Starter
How do I go about fixing it?
post #6 of 12 Old 05-26-2014, 07:21 PM
Hate stupid people
Quoted: 140 Post(s)
Originally Posted by RollinEarly99 View Post
What he said!
Been there, done that when I had my E 99
EFI Live tuned 6.7
post #7 of 12 Old 05-26-2014, 07:23 PM
Hate stupid people
Quoted: 140 Post(s)
Pull the tire. Loosen caliper. Remove pads and slider clips. Clean clips and caliper. Then re install
EFI Live tuned 6.7
post #8 of 12 Old 05-26-2014, 07:29 PM
Quoted: 8 Post(s)
Don't forget to grease all moving parts as well... Expect where the rotor and brake pads make contact with each other of course
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 12 Old 05-26-2014, 07:36 PM Thread Starter
Thanks guys
post #10 of 12 Old 05-26-2014, 07:43 PM
ZMANN's Avatar
Quoted: 1584 Post(s)
keep an eye on it or heat gun LOL
your piston may have an issue internally so even after your grease everything it may hang
We Miss you Ronnie
ZMANN is offline
