rebuild rearend - Ford Powerstroke Diesel Forum
post #1 of 1 Old 05-21-2014, 06:17 PM Thread Starter
rrancourt's Avatar
rebuild rearend
After many, many, many hours of deliberation I am going to change out the clutch pack in my LS rear. I've heard that the bearing preload is controlled by shims. Question is how do you check the preload is correct when you get it back together? After 200k, simply putting it back together the way it was will probably not give the correct preload, I'm assuming some wear has been taken place and they will need to be adjusted when reassembling.
2005 F350 Lariat Crew-cab Long Box
Upgraded FICM with PHP Hercules tune
Edge Insight with EGT probe and Turbo timer
Diamond Eye 5" Performance exhaust with muffler delete
Blue spring update
High Idle Mod
rrancourt is offline
