2004 6.0 crazy steering issue - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-22-2014, 10:06 AM Thread Starter
Ok so recently I replaced the power steering, so I am thinking this issue may be the steering box or track bar. my mechanic says everything else looks fine, I.e. ball joints, etc
the issue: I'm going into a turn and I obviously am turning the wheel. when I am trying to come back to center the wheel fights me pretty hard like it doesn't want to go back the way I want it to. after I return the wheel to center there is now a few inches of play and the wheel is constantly grabbing left, right, left right..in a very wobbly manner. if I drive i get on the brakes a bit it seems to help or if I just bear through it and drive straight, it'll eventually go back to pretty much normal (only like 1/2inch of play and no wobbly
left to right). but as soon as I go into another turn it'll fight and wobble back and forth.
I have It lifted 4" with 35s on 20s. i did an aftermarket steering stabilizer and like I said, already relaxed the power steering bc it was doing this before. it was great after that for about 3 weeks and now it is back
to doing it again. there is also some wine I think I hear too. maybe a new ps pump, box? thoughts?? thank you!
rdc04_6.0 is offline
post #2 of 6 Old 04-28-2014, 06:40 PM
Quoted: 2 Post(s)
Probably not your issue, but a few years back, my truck seemed to run fine while driving, except after doing a big sharp turn on pavement my truck would go left to right, I had to fight it to bring it back after a 3-5 wobbles. Lifted the front of the truck to find some worn out ball joints. Replaced them all and it was good after that.
Sounds similar, but you said yours were good....
RcAirboat is offline
post #3 of 6 Old 05-08-2014, 07:32 PM
I had this and it was a seized u joint
03 f350 is offline
post #4 of 6 Old 05-15-2014, 04:27 PM
Quoted: 2 Post(s)
My '06 F250 with 205k, just started doing the exact same thing your was doing about 3 weeks ago. Took it today and got the front end looked at and the gave me a list of things that had gone bad with my front end
-Both lower ball joints
-Front U-joints
-Right-outer tie rods
about a $900 project including labor is what I was quoted. My question to anyone out there is, what is a good aftermarket brand for these products that I should use to replace the OEM parts. simply because the OEM parts on this model have sealed grease fittings.
06StrokeofPower is offline
post #5 of 6 Old 05-18-2014, 09:26 PM
Most people will say moog is think. That's what I did
03 f350 is offline
post #6 of 6 Old 05-19-2014, 05:36 AM
sbluke55's Avatar
Quoted: 622 Post(s)
Garage
Replace your upper ball joints while your in there. It would suck if they went bad in a few thousand miles. Moog is ok. I've heard there products have declined in quality. I know a lot of the dodge guys are going raybestos over Moog.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
