Problem after brake pad change - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-20-2014, 11:08 AM Thread Starter
2004 F250 king ranch
Replaced front brake pads yesterday. Now driving down the road it's pulling fairly hard to the right - while traveling - not just when braking. Wasn't doing this before. Any ideas? Could my right side brakes be partially engaged non stop for some reason??? Thanks
brownf is offline
post #2 of 2 Old 04-20-2014, 01:45 PM
Dub976's Avatar
Sounds like a stuck piston. Try cleaning the piston and lube it up. Otherwise when I did mine, I noticed the shims were extremely tight on the pads/bracket. It could cause the pad to hang up.
2007 harley f250 6.0l almost stock except for a looney tune, coolant filter, cai, cat back/cat delete, ported intake manifold, studded with a new oil cooler and egr delete. with a edge cts to keep an eye on things.
Dub976 is offline
