Weird vibration - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-06-2014, 07:37 PM Thread Starter
jake_duet's Avatar
Weird vibration
Driving around town today, and I hit a bump in the road, and all of a sudden had this weird vibration in my feet.. Then hit the next bump and it quit vibrating? Then probably 30+ bumps later it started again, but the next bump made it stop?
Early build 2004 Ford F-250 6.0
S&B Intake
EGR Delete Kit
4" Diamond Eye Turbo Back Straight Pipe
blue spring upgrade
updated oil cooler
Edge Insight CTS monitor
GlowShift boost, fuel psi, and oil psi gauges in pillar pods
08 tail lights, 05 headlights
Mf. Date July, 2003
"Keep on Strokinn"
jake_duet is offline
post #2 of 4 Old 03-06-2014, 08:18 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Sway bar end links
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 4 Old 03-06-2014, 08:28 PM Thread Starter
jake_duet's Avatar
I just had everything changed and replaced in the front
S&B Intake
EGR Delete Kit
blue spring upgrade
updated oil cooler
Mf. Date July, 2003
"Keep on Strokinn"
post #4 of 4 Old 03-14-2014, 10:57 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 581 Post(s)
Garage
How is the steering stabilizer ?
Track Bar :
Ball joint
Bolt through end on frame mount. If there is play there it will give occasional shaking.
The front axle is moving around on you somewhere, could even be steering parts including play in steering box.
Start with getting someone in truck to move steering wheel back and forth looking for play.
Good Luck
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
Tags
bumpy road , front end , vibration
