4x4 not working - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-04-2014, 11:03 AM Thread Starter
4x4 not working
My 4x4 will not come on lights come on when starting but not when I turn the switch to. 4x4 nothing no lights nothing! I've replaced the switch replaced the front hubs and replaced both relays under the hood since replacing the relays the fuse in the fuse box keeps blowing as soon as I plug a new one in! Is there something else I'm missing !!! Any advice would be greatly appreciated!! Thank you
tony4200 is offline
post #2 of 3 Old 03-04-2014, 11:22 AM
E99F350Stroker's Avatar
Have you tried searching your question? a lot of people have similar problems. Also have you checked to see if the transfer case drive shaft is rotating when you turn the switch on? If the drive shaft doesn't turn you can at least narrow it down to a problem that is just getting the transfer case to engage.
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
post #3 of 3 Old 03-08-2014, 03:39 PM Thread Starter
I can manually take the shift pump off turn the rod and put it In 4 high and the light comes on it drives and runs fine but I guess the shift pump on the transfer case isn't getting power somewhere
tony4200 is offline
