Shaking 50-60 in overdrive - Ford Powerstroke Diesel Forum
post #1 of 20 Old 02-28-2014, 03:28 PM Thread Starter
Hey guys I have an 04 F-250 and just the last couple of days it's starting to act up. When I get between 50-60 mph with the truck in overdrive it starts to shake real bad. It only does it if the truck has shifted in to overdrive, if it's in any other gear at that speed then it doesn't shake. Just trying to figure out if this would probably be a tranny problem or u joints or something. The truck still shifts perfect and no other signs point towards anything being wrong with the tranny. Thanks!
Tx2va07 is offline
post #2 of 20 Old 02-28-2014, 06:32 PM
PowerstrokeDriver2's Avatar
Bad injector.
2006 Ford F-250 XLT FX4 REGULAR CAB
SCT Tuner
Edge Insight CTS
IDP Tunes (Tow, Extreme Street, Extreme Race)
5" Turbo Back Exhaust
Stock TTY Head Bolts
BPD 58V FICM
S&B Cold Air Intake (Dry Filter)
PowerstrokeDriver2 is offline
post #3 of 20 Old 02-28-2014, 08:16 PM Thread Starter
Really? Didn't seem to me like that would be it since it only does it at the one speed and the truck runs great otherwise, no smoke or anything.
Tx2va07 is offline
post #4 of 20 Old 03-01-2014, 06:27 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Does it smooth out after it warms up to op temp, bad injector. or stiction.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #5 of 20 Old 03-01-2014, 08:27 PM Thread Starter
Yeah today was the first time since it's been doing it that I drove it on the highway on kind of a long drive. It did seem like once it got up to full temp that it wasn't doing it anymore.
Tx2va07 is offline
post #6 of 20 Old 03-02-2014, 04:19 AM
Quoted: 285 Post(s)
How many miles to oil change, what weight oil are u running. If your not running syn oil then change 5w40 syn and add archoil or rev x, then take it out and run it like u stole it for a little while to help clear up the stiction.
-Tom
post #7 of 20 Old 03-02-2014, 05:10 AM Thread Starter
I just had the oil changed at the Ford house 2 days ago so yesterday was the first time I really drove it since and it seemed like it did better. I did do a lot of stomping on it yesterday too in case it was stiction like you had said. I ran a bottle of RevX fuel additive thru it a couple of months ago, I will pick up a bottle of the oil additive and run that thru also. Also on my Insight when I'm at WOT the IPR is maxing at 85%, I never monitored this before but I would assume that's supposed to be 100% at WOT, right?
Tx2va07 is offline
post #8 of 20 Old 03-02-2014, 05:25 AM
Quoted: 285 Post(s)
Not sure on that percentage, someone will chime in on that i`m sure. Are u running an oil bypass filtration system on the truck, that really helps to clean up stiction.
-Tom
post #9 of 20 Old 03-02-2014, 05:27 AM Thread Starter
No sir, I don't have one of those
2004 F-250. 8" Pro Comp lift. 38" Toyo MTs. EGR delete. 4" MBRP straight pipe. Air Raid intake. SCT tuner. Edge Insight CTS.
Tx2va07 is offline
post #10 of 20 Old 03-02-2014, 05:41 AM
Quoted: 285 Post(s)
Ok from my experience, my 03 for what it`s worth does not like dyno oil (15w40) . I run 5w40 syn with a oil bypass with amsoil filter, lot of others on this site also do this for the life of the injectors. With that said my 03 suffered from stiction, after the oil switch haven`t had a problem in 50,000 miles.
-Tom
