on a 1-10 scale how dangerous is... - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-23-2014, 05:32 PM Thread Starter
so I just replaced the passenger side hub assembly and got the one with the coarse threads on accident.... the only parts store in town only had 4, M14x2.0 lug nuts... so i currently only have 4 on one of the wheels. Ordered some online should be here by the end of the week.... how dangerous is driving around with only 4
2003 6.0 F250 "Onyx"
4inch lift
35'' Falken Wildpeak AT
SCT FX3 Performance tune
Edge Insight CTS
Edge EGT probe & Fuel Pressure sensor
Blue spring upgrade
Bulletproof Diesel EGR Cooler
Updated Motorcraft Oil Cooler
Sinister Diesel Coolant Filter
Rotella ELC
MBRP 4'' Turbo Back SS Straight pipe
Alpine head unit
Rockford Fosgate speakers
Still need to stud it....
aeby07 is offline
post #2 of 13 Old 02-23-2014, 05:47 PM
ZMANN's Avatar
Quoted: 1667 Post(s)
no one in there right mind will say it's ok just because something can go wrong
would i do it ? maybe just tot he store to put on the other 4 ones and only if the store was really close LOL
your going to run an oddball setup ??
We Miss you Ronnie
ZMANN is offline
post #3 of 13 Old 02-23-2014, 06:21 PM
Heavy_GD's Avatar
Quoted: 1569 Post(s)
Feedback Score: 3 reviews
The fact that you posted this means you know its a bad idea
GD
Heavy_GD is offline
post #4 of 13 Old 02-23-2014, 06:35 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
I'd find 4 fine thread studs/ nuts and pop the course ones out before ever driving around with 4 lug nuts.
The fine threaded studs/nuts are much more common, they should be easier to find
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 13 Old 02-23-2014, 08:23 PM Thread Starter
they are WAY easier to find and i didnt realize at the time how easy the studs were to pop out untill someone told me how to do it after I finished putting the old hub back on (twice because I forgot to put the yellow O ring on the first time -_-) I ordered some lugs from Ebay. Ill keep the driving to a minimum and possibly even swap out the studs from the old one in the next few days
4inch lift
Edge Insight CTS
Blue spring upgrade
Rotella ELC
Alpine head unit
aeby07 is offline
post #6 of 13 Old 02-25-2014, 03:30 AM Thread Starter
Well I quit being lazy and swapped out the studs from the old hub. I saved $160 bucks by not buying the hub with the fine threads. If anyone is swapping a hub I recommend going this rout.
4inch lift
Edge Insight CTS
Blue spring upgrade
Rotella ELC
Alpine head unit
aeby07 is offline
post #7 of 13 Old 02-25-2014, 03:19 PM
what is the part number for the hub? where did you get it?
2006 f250 ccsb, 6.0l
unknown 4" SS turbo back with a muffler.
edge evo(unhooked) just a dash piece.
samsung tab 3 running- torque pro, gps, and music.
cool front bumper.
19?? F?50
1985 3/4ton frame
1986 1 ton axles kingpin dana60 10.25 rear
1995 body,
1995 EFI 4.9l (300) I-6 ported polished and cammed
1979 NP435 granny low with a custom built hydro clutch
1984 NP208 transfer case
Torque Monster
fordtrucknut is offline
post #8 of 13 Old 02-25-2014, 05:15 PM Thread Starter
http://www.autozone.com/autozone/par..._434638_0_6542
Here is the link. Autozone has a sale right now 20% off orders $100 or more so you save a bunch, just make sure you input the code. I just read the description and it clearly states "course threads" and in the "stats" says lug size M14x1.5 .... not the case, the course studs are M14x2.0 Ill never know why the fine thread option is 2x the price
4inch lift
Edge Insight CTS
Blue spring upgrade
Rotella ELC
Alpine head unit
aeby07 is offline
post #9 of 13 Old 02-25-2014, 05:23 PM Thread Starter
Timken 515020
is the part number
4inch lift
Edge Insight CTS
Blue spring upgrade
Rotella ELC
Alpine head unit
aeby07 is offline
post #10 of 13 Old 02-25-2014, 07:04 PM
ppffftttt got all excited for nothing..... those are for early trucks i've got an 06
cool front bumper.
19?? F?50
1985 3/4ton frame
1995 body,
Torque Monster
