Power steering - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-16-2014, 11:02 AM Thread Starter
Flooringit's Avatar
Quoted: 27 Post(s)
Power steering
Buddies 2004 looses powersteering as soon as you let of diesel pedal. Flushed it with new fluid. Didn't help. Plus it sometimes don't want to stop. Does it have a vacuum problem or need a new powersteering pump?
2007 outlaw.
sct x3
gearhead tunes srl
swamps 58volt ficm
php ficm programming
xd hoss machined face rims
with toyo mts 35x12.50x20
icon 4.5 lift
top gunz steering stabilzer
headstuds and egr delete coming soon
Flooringit is offline
post #2 of 5 Old 02-16-2014, 01:56 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
Sounds to me like the power steering pump must have just become weak. How well do his brakes work( because the PS system acts as a hydrobooster for the breakes). Because of the weak pump the engine has to run at a higher rpm to turn over the PS pump faster to create easier steering.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #3 of 5 Old 02-16-2014, 11:03 PM Thread Starter
Flooringit's Avatar
Quoted: 27 Post(s)
Sometimes work fine others won't stop. Power steering pump isn't much. Doesn't look hard to change has anyone done it?
2007 outlaw.
sct x3
gearhead tunes srl
swamps 58volt ficm
icon 4.5 lift
post #4 of 5 Old 02-24-2014, 07:40 AM
I just had the brake booster and PS pump changed. I guess it gets contaminated and needs to be flushed. Sounded like a PITA, I'm glad someone else did it!!
2006 F350 4x4 CC Lariat
scottbob99 is offline
post #5 of 5 Old 02-24-2014, 07:26 PM Thread Starter
Flooringit's Avatar
Quoted: 27 Post(s)
Well I bought a pump I'm close to getting it off. It's been all nuts and bolts so far. But I ran into a problem. Getting the fan off sucks! Basically a 1 7/8 wrench and you hit it till it breaks loose. Some people uses a air hammer. But heard that can damage the nut. Wouldn't be so bad if you could get a great swing at it
2007 outlaw.
sct x3
gearhead tunes srl
swamps 58volt ficm
icon 4.5 lift
