smoked hub bearing - Ford Powerstroke Diesel Forum
 13Likes
post #1 of 36 Old 02-15-2014, 12:36 PM Thread Starter
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 111 Post(s)
Feedback Score: 7 reviews
smoked hub bearing
thought it was a trashed caliper, but after replacing it.... needs new hubs assembly. not a fan of unit bearing assembly's. so much cheaper to replace bearings by them selves.
unfortunately i will be underway all next week and won't get to fix it until saturday and i have duty sunday. crap!
are there any special tools required to pull the old hub assembly and pop on a new one? only the drivers side is toast but i will be doing both sides.
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #2 of 36 Old 02-15-2014, 12:39 PM
ZMANN's Avatar
Quoted: 1782 Post(s)
buy only a Timken brand like the OEM if u are keeping the truck but they are available at Amazon and autozone
u need a long set of circlip removers for the clip and some folks get the new studs
instead of transferring them
We Miss you Ronnie
ZMANN is offline
post #3 of 36 Old 02-15-2014, 01:16 PM Thread Starter
BBBRRRRRTTTTT
Quoted: 111 Post(s)
circlip removers?
post #4 of 36 Old 02-15-2014, 02:34 PM
midnite rider's Avatar
Quoted: 285 Post(s)
It` a spring type clip that holds your planitary gear in your hub, it looks kinda like a slinky. If your careful it can be removed with 2 small screwdrivers, it spins out.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #5 of 36 Old 02-17-2014, 02:13 AM Thread Starter
BBBRRRRRTTTTT
Quoted: 111 Post(s)
looks like a horseshoe? same as c clips? use snap ring pliers to remove them?
post #6 of 36 Old 02-25-2014, 02:15 AM
They call me Pete's Avatar
Halfway though doing my driver side. I chose to replace the studs. Yup taking the easy way out. I wrestled with one and said screw this. Would be nice if you could get the hub assembly with them in it already. Maybe some do but not the one I got from NAPA. Next day off doing passenger side
They call me Pete is offline
post #7 of 36 Old 08-19-2015, 08:14 AM Thread Starter
BBBRRRRRTTTTT
Quoted: 111 Post(s)
turned out it was just the caliper, but i have the unit bearings and i'm going to do them anyway...
is there a build thread for this somewhere? on page 6 of search and i'm not finding anything.
post #8 of 36 Old 08-19-2015, 09:34 AM
6.0Stroker's Avatar
Quoted: 956 Post(s)
All I had on mine was a the band clip that holds the 4wd hub lock out on, and then inside there is a snap ring.. good pair of snap ring pliers and comes right out..
Also, no need to change studs.. you can order the timken ones with the suds already in them in either thread pitch..
at least you could on mine
MIKE "HOSS" THOMAS
'03 F350 6.0 6-speed
~EGR Delete~Ported Intake Manifold~4in Diamond Eye Dual Exhuast~Blue Spring~50MM Turbosmart BOV~PMM Coolant Filter~
~155/stock Warren Injectors~Terminator Engineering T500 HPOP~SouthBend Dual Disc Clutch~RCD Stg 2 Camshaft~
~'03 Nighthawk turbo w/Wicked Wheel2
~Rebuilt and Studded by Toren~
6.0Stroker is offline
post #9 of 36 Old 09-17-2016, 05:38 AM
Hello,I have 2003 f250 sd. Took it on a 350 mile trip, I started hearing a noise that I thought was a wheel bearing going bad, but when I arrived at my destination I jacked it up, both sides and neither wheel budged or made the grinding noise you would expect. Now I'm thinking a bad caliper, is that possible
Tomj010 is offline
post #10 of 36 Old 09-17-2016, 06:37 AM
ZMANN's Avatar
yes it is possible , it could also be a axle u joint or spindle bearing inside the unit bearing but replaceable separately
time to pull some parts and inspect IMO
We Miss you Ronnie
ZMANN is offline
