Sway bar/steering linkage ?'s with pics - Ford Powerstroke Diesel Forum
post #1 of 20 Old 02-13-2014, 06:56 PM Thread Starter
I know typically suspension parts shouldn't have lateral play in them but just wanted to make sure on this.
http://i1347.photobucket.com/albums/...pse4e31623.jpg
That picture is the sway bar link that's in front of the radiator, pushed all the way to the driver side of the truck, give it a good tug and this:
http://i1347.photobucket.com/albums/...ps7aec9f03.jpg
You can see it moves quite a bit back in forth, what's the problem here? Do the end links need to be replaced or do I just need bushings?
Kind of a cruddy picture but there's all kinds of grease or some **** around the gearbox, time to replace? Will get a better picture if need be.
http://i1347.photobucket.com/albums/...ps62ab6945.jpg
thanks guys.
Alpha Male is offline
post #2 of 20 Old 02-15-2014, 10:42 AM Thread Starter
Anyone?
Sent from AutoGuide.com App
post #3 of 20 Old 02-15-2014, 02:13 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Are u getting a clunking sound on rough roads or hitting bumps.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #4 of 20 Old 02-15-2014, 03:41 PM Thread Starter
Yeah. Kinda hard to here it going down the road or highway but going through neighborhoods slowly you can hear it really good. Almost sounds like if you took a single link in a chain and dropped it clunked it together with another piece of metal. Sounds stupid but that's the only way I can explain it.
post #5 of 20 Old 02-15-2014, 04:22 PM
Quoted: 285 Post(s)
I would change swaybar bushings. Use polyeurothane ones they last longer
-Tom
post #6 of 20 Old 02-15-2014, 05:57 PM Thread Starter
Okay. How hard of a job is that?
I imagine not very hard just never done it before. I'm installing 2.5" leveling coils and PMF adjustable track bar and alignment cams this week so imagine it'd be a good time to do bushings as well. Where can I get these poly bushings? What about neoprene bushing?
post #7 of 20 Old 02-15-2014, 06:50 PM
Quoted: 285 Post(s)
Any parts store should have em. Takes about 20 minutes. 4 bolts swaybar swings down remove old ones, install new ones done : )
-Tom
post #8 of 20 Old 02-15-2014, 06:55 PM Thread Starter
Awesome, do I just take the bushings to the store and they match them or should they just have some? Haha.
post #9 of 20 Old 02-15-2014, 07:30 PM
Quoted: 285 Post(s)
They will want to no the diameter of your swaybar. I think there are 2 different sizes. piece of cake.
-Tom
post #10 of 20 Old 02-15-2014, 07:39 PM
ZMANN's Avatar
Quoted: 1477 Post(s)
those little protrusions on the bar are the stops that keep it centered and stops it from sliding into the bushing if you have a lift and your axle is off center it will push the swaybar over and screw up the bushing
you will also find those bushings hard to find for the 05 -07 trucks I had to go ford
as far as poly the OEM's lasted 100k on mine I just changed them for the hell of it your look fine but you can unbolt the saddles and unclip the bushing to inspect
We Miss you Ronnie
ZMANN is online now
