4x4 issue - dash lights won't even come on - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-12-2014, 06:08 PM Thread Starter
2004 F250 King Ranch with 6.0 and turn knob 4wd - manual hubs
4wd lights activate when cranking the truck but will not come on when I try to use 4wd and 4wd isn't working. Any and all advice would help bc we are getting a lot of ice right now and I can't sit in this house much longer! Lol. Thanks!
brownf is offline
post #2 of 11 Old 02-12-2014, 06:10 PM
Heavy_GD's Avatar
Quoted: 1738 Post(s)
Feedback Score: 3 reviews
start with fuses and relays under the hood.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #3 of 11 Old 02-12-2014, 06:31 PM Thread Starter
Checked all 4wd related fuses under dash. Gotta figure out where all other relays etc are on the truck and what they look like and what to look for. I'm far from being a mechanic - just tryin to learn as I go! I hope I can get this thing by myself so I don't have to put it in the shop
brownf is offline
post #4 of 11 Old 02-12-2014, 06:48 PM
Heavy_GD's Avatar
There are two ESOF relays in their own box, driver side fender mounted, right next to the brake reservoir.
Often times they are mounted upside down and the lid fills up with water damages the relays.
One shifts the transfer case into 4x4, the other shifts it out.
GD
...because Patriot.
Heavy_GD is offline
post #5 of 11 Old 02-12-2014, 06:51 PM
roche837's Avatar
Quoted: 6 Post(s)
Garage
Feedback Score: 4 reviews
Exactly, mine were mounted correctly but were still failed, I believe low gets power from 4 HI so if one relay fails both will not function.
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #6 of 11 Old 02-12-2014, 07:03 PM Thread Starter
Oreillys has a part listed for my truck called the 4wd actuator. Where is that located and could that also be the problem? Planning to check possibilities tomorrow
brownf is offline
post #7 of 11 Old 02-12-2014, 07:39 PM
roche837's Avatar
Quoted: 6 Post(s)
Garage
That's the transfer case motor itself bolter to the t-case. I would go look at those relays before you go buying a new actuator.
roche837 is offline
post #8 of 11 Old 02-12-2014, 07:41 PM
roche837's Avatar
Quoted: 6 Post(s)
Garage
Also just incase you did not know, 4 Lo will not engage unless the truck is in neutral, 4 Hi should be able to be engaged "on the fly".
roche837 is offline
post #9 of 11 Old 02-13-2014, 02:17 PM Thread Starter
It was the relays. 20 bucks and 2 minutes and I was good to go. Thanks guys! Got me out of the house in all this snow and ice
brownf is offline
post #10 of 11 Old 02-13-2014, 02:43 PM
Heavy_GD's Avatar
Good deal, thanks for circling back
GD
...because Patriot.
Heavy_GD is offline
