4x4 problem - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-08-2014, 09:43 AM Thread Starter
midnite rider's Avatar
Quoted: 285 Post(s)
Unhappy 4x4 problem
Ok guys my turn in the barrel,4x4 inoperative checked fuses under dash hubs are locking in light on dash comes on and front driveshaft locks in wheels won`t engauge. any thoughts or help would be thankful. p.s. manual warn hubs
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #2 of 10 Old 02-08-2014, 09:53 AM
Heavy_GD's Avatar
Quoted: 1427 Post(s)
Feedback Score: 3 reviews
I wasnt clear on the "hubs are locking in"
Does it work when you lock the hubs manually?
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #3 of 10 Old 02-08-2014, 10:16 AM Thread Starter
Quoted: 285 Post(s)
sorry they are manual warn hubs. they do lock the axles in. i layed down while my son moved truck back tires spun front shaft did not turn hope that helps
-Tom
post #4 of 10 Old 02-08-2014, 10:48 AM
wvrrcarknocker's Avatar
Quoted: 2 Post(s)
Send a message via Yahoo to wvrrcarknocker
If the front shaft did not turn, doesn't that mean the transfercase isn't shifting? Do you have ESOF or manual transfercase? With a Lariat, i'd assume its ESOF. If so, are the lights coming on when you turn the ignition on? If not, the issue is with your shift motor. If the lights are working, and they shift correctly, I would suspect a bad ESOF relay. There are two ESOF relays in their own box, driver side fender mounted, right next to the brake reservoir. Often times they have been found mounted upside down and the box lid fills up with water and submerges the relays. One shifts the transfercase into 4x4, the other shifts it out. The one that shifts in kinda sounds like it could be your issue. Sorry if I repeated anything you already knew, I explained it in such a way that someone who has no idea can understand it.
Originally Posted by ChiefRocka View Post
Great truck, but ugly and I felt like I was driving a penis down the road .....
wvrrcarknocker is offline
post #5 of 10 Old 02-08-2014, 11:19 AM Thread Starter
Quoted: 285 Post(s)
its esof when truck starts light comes on then goes right out when i turn swtch to 4x4 light comes on when i switch to 4 low low range light doesn,t also there is power to the 2 relays under the hood. i`ll check the relays see what happens there thanks for the input drivetrains with electric issues mess with my head sometimes LOL
-Tom
post #6 of 10 Old 02-08-2014, 12:16 PM
ZWilson07's Avatar
Not gonna lie that was pretty hard to read without some pauses put in there lol.
But sounds like to me that your transfer case isn't shifting in and working properly. Try getting under there and tapping on the side of the transfer case. A lot of times this helps to free it up if it hasn't been used in awhile, just be careful when doing it.
Personally if I was you id lift the whole truck off the ground so you can really tell what is going on with ease instead of trying to do it on the ground. If your hubs work, and its not an electrical problem, then the only thing left is the transfer case itself.
  • 1990 F250 RCLB 7.3 IDI 4x4 ZF5. 45,000 original miles and factory original as can be.
  • 2006 Dodge 3500 QCLB DRW 5.9 CR G56.
  • Vehicles for days!
Will never buy anything from IPR and Sinister! List still growing
ZWilson07 is offline
post #7 of 10 Old 02-08-2014, 12:31 PM Thread Starter
Quoted: 285 Post(s)
I checked the relays with a multimeter and both the ohm reading checks out and the beep test checks out on them. The only thing I can think of now is that the shift motor isn't working.
I don't have a way of getting the truck completely off the ground.
I have been using the 4x4 all the time due to this terrible winter were having, so IDK if it's stuck or not... I'll try tapping on it and see if it's sticking.
-Tom
post #8 of 10 Old 02-08-2014, 03:02 PM Thread Starter
Quoted: 285 Post(s)
Thanks guys found the problem. internal snap ring on the back of the two piece planetary gear in hub let loose on passenger side. why front driveshaft wouldn`t turn idk. thanks again :-)
-Tom
post #9 of 10 Old 02-08-2014, 03:04 PM
anschutz1913's Avatar
Quoted: 46 Post(s)
Sent from AutoGuide.com App
-Tom
2003 F350 CCSB Lariat. 316K. Everything but the studs.
Originally Posted by Justin M View Post
I really think the previous owner should be kicked in the crotch by a buffalo
anschutz1913 is offline
post #10 of 10 Old 02-08-2014, 03:09 PM
Quoted: 46 Post(s)
Btw everyone I'm his son. I helped him and it turned out to be up in the hub. We listened to the shift motor up on the transfer case and it was actuating just fine. So I figured I would check the front axles and just happened to stumble across the passenger side one not locking in when the hub was locked in.
Thanks for all your help!
-Tom
