Brake Issue - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By 05F350Lariat
post #1 of 8 Old 02-05-2014, 06:52 PM Thread Starter
05F350Lariat's Avatar
Brake Issue
About 3 or 4 weeks ago I had what I thought was my drivers side rear parking brake lock up on me. When I got home after driving around town it was very hot and had a decent amount of smoke coming off it. After letting it cool I jacked up the back end and beat it with a dead blow hammer which seemed to work as the tire moved freely. Then last night when I got home and hopped out of the truck I could instantly smell hot brakes and the rotor was glowing. Thinking about it over the last few months every once in a while I've noticed the same smell of burnt brakes, it was just never that bad and I didn't think much of it. So it sounds like this is not a new issue and it maybe getting worse.Does it sound like my brake caliper on that corner is going bad? If so does anyone know about how much a replacement is?
Fosterslaw77 likes this.
2005 F350 Lariat CC LB 4x4
SCT Livewire with EGT Probe, IDP FICM Programmer, 175/30 Renegade Diesel Injectors, ARP Head Studs, EGR Delete, STC Fitting Upgrade, Turbo Oil Feed/Return Line Upgrade, Blue Spring Kit, BullyDog CAI, Accufab Intake, FS2500 Oil Bypass Filter, Coolant Bypass Filter, Mean Green HO Alt., IDP Long Y Pipe, MBRP 5" SS Turbo Back Exhaust.
05F350Lariat is offline
post #2 of 8 Old 02-06-2014, 05:29 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Caliper is definitely hanging up. Reman calipers aren't very expensive.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 8 Old 02-06-2014, 05:32 AM
Fosterslaw77's Avatar
I used napa all 4 corners. They have lifetime warranty and we all know in areas of heavy salt use they never last long. I plow and tow with truck always strong braking.
Fosterslaw77 is offline
post #4 of 8 Old 02-06-2014, 03:53 PM
midnite rider's Avatar
Quoted: 285 Post(s)
yep caliper mine is always on front that can get interesting
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #5 of 8 Old 02-09-2014, 01:36 AM
Rivan's Avatar
I want in on this thread because just today I was running some errands and when I was dropping my buddy off, I noticed a terrible (burning brake) smell.....I asked if that smell was just outside or if it was coming from my truck? It was also my rear right that the smell was coming from, and that wheel was way warmer than the others...I wonder how long this has been going on for and if this is causing my sh*tty fuel mileage. I don't think it's my park brake, how do you tell for sure if it's the calliper or e-brake?
Rivan is offline
post #6 of 8 Old 02-09-2014, 05:20 AM
Quoted: 285 Post(s)
The rotor would probably be hot i would think.
-Tom
post #7 of 8 Old 02-09-2014, 08:48 AM
NYC F-350's Avatar
Quoted: 49 Post(s)
Originally Posted by Rivan View Post
how do you tell for sure if it's the caliper or e-brake?
Take it apart and look at it. You'll know real quick
Please
post #8 of 8 Old 02-09-2014, 03:49 PM
Rivan's Avatar
It only just started dragging slightly...not to the point to where I could really feel it slowing me down or it wasn't to the point of smoking but it all felt hot to the touch (calliper and rotor) and had the burning smell
I guess it's going up on the jack stands and I'll have to have a looky-loo
Rivan is offline
