4x4 ? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-22-2014, 06:23 AM Thread Starter
4x4 ?
hey all , I have a question im experiencing a issue with making sharp turns when in 4x4 let me start by letting u know what I have and my issue. my truck is a f350 4dr 8ft bed, when im in 4x4 hubs in auto and making a sharp turn left or right it feels like the front is jerking like its to sharp of a radius for the long wheel base if anybody has had this issue or if this is common for such a long truck please let me know, thanx danny
dannyreed is offline
post #2 of 6 Old 01-22-2014, 06:25 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
dry road? if so normal....my dually does it even on ice because of the LS rear...with that vauge of a description hard to tell if something is actually wrong
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
The Following User Says Thank You to dannanw For This Useful Post:
Heavy_GD (01-22-2014)
post #3 of 6 Old 01-22-2014, 06:33 AM Thread Starter
sorry... Its on snow, slush and ice, its almost like the rear is trying to push the front end.. kinda like the gearing is different but the truck is all original, there is no clunking or grinding it goes in and out of 4x4 with no issues...
post #4 of 6 Old 01-22-2014, 06:35 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
check the axle tags, if the rear has ls then a little of that is normal...I'd also try to see if it does it in non-auto on the hubs to rule the auto part of it out as it's a common issue on those (my work 6.0's dont work)
dannanw is offline
post #5 of 6 Old 01-22-2014, 06:38 AM Thread Starter
can do I should be able to get to it before the am, I will post back my findings
post #6 of 6 Old 01-29-2014, 08:27 AM
Quoted: 9 Post(s)
On dry road, virtually all 4wds do this. All of the wheels are being driven so due to the wheels needing to travel different distances around the circle you are making usually the inside rear wheel or front wheel will need to "spin out" a little bit. Due to the suspension absorbing what it can and then releasing when the wheel starts to slip you get the jerking.
Obviously it could be something else since I am not there to witness it, but what you are describing sounds normal.
A locked two wheel drive rear axle will do the same thing only it is not as noticeable.
divotf15 is offline
