u-joint leaking oil - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-20-2014, 08:01 AM Thread Starter
u-joint leaking oil
The u-joint where my drive shaft connects to me rear differential box is leaking oil, any idea of what is making it? Only after the engine is warmed up does it leak. Check the oil and it is within range. started happening about 2 weeks ago with random oil stains on the driveway but today I saw it dripping down the rear differential box and followed it to the u-joint and drive shaft connection. My rig is a 2006 F250 2WD rear wheel. I run Rotella T Triple Protection. Hope this helps and thanks for all advice.
lpnsteve is offline
post #2 of 7 Old 01-20-2014, 08:06 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
If the leak is where the yoke enters the rear differential, that is a pinion seal leak.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 7 Old 01-20-2014, 08:09 AM
NYC F-350's Avatar
Quoted: 49 Post(s)
Does it look like this? (pic only to show location. Not a Ford axle)
Please
The Following User Says Thank You to NYC F-350 For This Useful Post:
lpnsteve (01-20-2014)
post #4 of 7 Old 01-20-2014, 08:12 AM Thread Starter
Yeah thats exactly what it looks like, although it is a trickly of oil down the differential box.
lpnsteve is offline
post #5 of 7 Old 01-20-2014, 08:26 AM
NYC F-350's Avatar
Quoted: 49 Post(s)
Like I said, that is a Pinion seal.
Unless you are comfortable setting gear clearances, bring it to a shop.
Please
post #6 of 7 Old 01-20-2014, 08:58 AM Thread Starter
is it a 10.50 ring gear or 11.25?
lpnsteve is offline
post #7 of 7 Old 01-20-2014, 08:59 AM
NYC F-350's Avatar
Quoted: 49 Post(s)
10.50 ring gear
Please
