hub question and help would be great - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-16-2014, 03:14 PM Thread Starter
06/powerstroker's Avatar
Ok i have a 2006 f350 4x4 with the 6.0 i get a shake only when braking around 40 and above grown to live with it ,know my abs light came on code reads c1155 left speed sensor looked around people say replace hub. Is it possible that the hub is also causing my shake and can a hub go bad without making any sounds. And if it helps there timken hubs on the truck. I dont really want to spend $400 or so if i dont need to. Thanks for the help
06/powerstroker is offline
post #2 of 4 Old 01-17-2014, 03:01 PM
midnite rider's Avatar
Quoted: 285 Post(s)
does the truck pull right or left when braking
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #3 of 4 Old 01-17-2014, 05:30 PM Thread Starter
No it doesnt . Everything feels like it should.
post #4 of 4 Old 01-18-2014, 05:24 AM
Quoted: 285 Post(s)
sounds like it i would pull wheels and brakes and check hubs hopefully eliminate guess work
-Tom
