Ladder bars? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-28-2013, 04:16 PM Thread Starter
gabelnj's Avatar
Ladder bars?
Hey all, it's been a very long time since I was on here last, however, I'm back. I have a new issue with my truck...
I am running close to 600HP and over 1000 foot pound torque. suspension is all stock minus helper air bags (haven't pressurized in a while). I have been burning bearings in y rear-dif. two weeks ago I threw a new ring and pinion at it, wound up having a horrible howling noise from the rear end. took it all apart and found...
1. all bearings are good
2. ring and pinion is good
3. pinion teeth marks found on spider gear casing
4. comparing old and new pinion, excessive ware on nose of old pinion compared to new.
Is axle wrap pushing new un-worn pinion into casing? who would diagnose more vs. just throw ladder bars at it and see what happens?
Thanks in advance!
gabelnj is offline
post #2 of 9 Old 12-28-2013, 05:01 PM Thread Starter
gabelnj's Avatar
who's off the shelf ladder bars are the best? Procomp, toughcountry etc.
Also I hate to bring this up... but I think I am going to switch out my MBRP 3.5 DP for a diamond eye 4 DP. I hope it will help my EGT gauge from jumping so quickly to 1200... who has any experience with temps switching from 3.5 to 4 DP, what did you see?
gabelnj is offline
post #3 of 9 Old 12-29-2013, 03:28 AM Thread Starter
gabelnj's Avatar
any one?
2004 CC/SB 4x4
EDE 5R110 rebuild/ bulletproof
Studs
Deletes..
EDE tunes
EDE VGT SR Turbo
EDE stage one sticks with hybrids
spearco intercooler
MBRP duals... want diamond eye 4inch DP
helper bags
Stock wheels and tires
need dyno
gabelnj is offline
post #4 of 9 Old 12-31-2013, 09:57 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Pick any of them, they are all similar in each category. However, you have to decide whether you want something for the drag strip, road or off-road use. I would suggest you ensure they don't bind and get the off-road style.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 9 Old 12-31-2013, 10:03 AM Thread Starter
gabelnj's Avatar
Thanks for the advice. after more research; I think the pinion was not installed properly as in it was not pre-loaded. This said I am still going to put ladder bars on considering the torque and large loads I occasionally pull... even looking into a solid drive shaft.
2004 CC/SB 4x4
Studs
Deletes..
EDE tunes
EDE VGT SR Turbo
spearco intercooler
helper bags
need dyno
gabelnj is offline
post #6 of 9 Old 12-31-2013, 10:32 AM
layson's Avatar
Quoted: 82 Post(s)
Look into a set from One Up Offroad and they work for all applications. They are expensive but you get what you pay for.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #7 of 9 Old 12-31-2013, 11:17 AM
05krsd's Avatar
My vote would be for One up Offroad or Top Gun Customs.
2005 F250 King Ranch, CCSB, FX4, 4.5 inch rough country lift, Edge Evolution tuner, studded, nitto terra grapplers 35s, custom exhaust, intake, hids. SOLD.
Looking for my next powerstroke.
05krsd is offline
post #8 of 9 Old 01-01-2014, 06:58 PM Thread Starter
gabelnj's Avatar
Looking at the ones from one up off-road. Leaning to the bolt on, don't wan to got brought the hassle of panting. Product description said the weld required set come as raw steel. Obviously to help with the welds. The top gun custom set were a little to "loud" for me. I am 100% worried about function and not appearance. What ever it takes to stop this axle wrap.
2004 CC/SB 4x4
Studs
Deletes..
EDE tunes
EDE VGT SR Turbo
spearco intercooler
helper bags
need dyno
gabelnj is offline
post #9 of 9 Old 01-01-2014, 07:49 PM
Dizzydd101's Avatar
look at some short bars like caltracs or assassins bars if its for racing
Dizzydd101 is offline
