Need conformation that this is the correct part and bind issue - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-28-2013, 07:55 AM Thread Starter
Strokergonebroke's Avatar
Hello all....2004 f250...all the bells and whistles engine wise...6in lift on 37's.
My first question is i notice my axial leaking behind the driver rear brake and was wanting to confirm that this part was what i need to fix the leak.
http://www.oreillyauto.com/site/c/se...2004&make=Ford
Second......the rear wheels are near impossible to turn by hand even when using the 37's as leverage.
No brakes are not dragging, i took them completely off rotor and all...AND yes it was in neutral....... no 4wd on.
When i spin the tires backward I literally have to muscle them and im no small guy by a long shot...spinning forward in maybe 10% easier......There is no free spin after moving not even a inch there that stiff.
no noise, binding, griding, clicking, heat, burning smells.....nothing i have no idea how long its been like this.
Only thing that was done is I changed my rear pinion seal and added fluid..nothing else.
I haven't dropped the axial yet to see if it the gears or transfer case,looking for ideas or tests to do.
Thank guys
-Kubic
2004 6.0...studded,sinister coolant filter,updated turbo lines,oil cooler,fuel spring,egr delete, 6in lift, 37 military tires, looney'd and podded.
Strokergonebroke is offline
post #2 of 2 Old 12-28-2013, 11:54 AM Thread Starter
well heres an update......
the rear axial spins fine....carrier bearing spins fine.......the bind in from the transfer case or transmission.
It seriously so hard to turn i cant do it buy the axial when unbolted from the rear diff.
any ideas or tests to do?
