Snap ring tool for 4x4 hubs??? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-29-2013, 10:49 PM Thread Starter
Quoted: 9 Post(s)
I've bought 3 sets of snap ring tools to use on the auto hub snap ring, but none have worked. Anyone else have this problem?
2005 Dark Blue F-250 Harley Davidson 4x4. SCT Livewire TS, 4" Silverline TBE, Sinister intake elbow, Riff Raff turbo boots, Blue spring, 6.4 banjo bolts, Sinister coolant filter, Fleetguard OAT, IPR EGR delete, ARP studs.
1998 Dodge Viper GTS. Silver/Blue stripes 1 of 21: Corsa exhaust, high flow cats, K&N filters, smooth tubes
Invasivore is offline
post #2 of 7 Old 11-30-2013, 03:33 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
You're not the only one, I get asked this question often
snap-on SRPC9000A for 05+ hubs. The snap ring is still quite hard to remove but these pliers are large enough to work.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 7 Old 12-01-2013, 07:42 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1697 Post(s)
yep, those are what I use any other tool other than that and they are a major PITA
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #4 of 7 Old 12-01-2013, 08:00 AM
ZMANN's Avatar
Quoted: 1469 Post(s)
lol I remember this , you are not alone
I finally had some special long reach SR pliers brought in to my local Grainger
pity the fool on the side of the road trying to do this as an emergency repair
I was just fixing an ESOF seal so I could put it back together every time I discovered my new SR pliers didn't, work I think i bought 4 pair before I found the right ones
We Miss you Ronnie
ZMANN is offline
post #5 of 7 Old 12-01-2013, 08:06 AM
^^^that's probably the greasiest I've ever seen the inside of these hubs look like
post #6 of 7 Old 12-04-2013, 10:14 AM
Nifty2Fifty's Avatar
That snap ring is such a PITA. When I did my ball joints, it caused many out bursts of swearing hahahah
2006 Ford F-250 6.0L
XDP Coolant Filter System - Bluespring Upgrade
Bushwhacker Pocket Style fender flares, Herculiner down the rockers
MBRP 4" Turbo back Exhaust
Nifty2Fifty is offline
post #7 of 7 Old 12-17-2013, 02:05 AM
RoCkfiSh363's Avatar
Yeah, I went thru 2 sets of Craftsman snap ring pliers before I got those red handled Snap On pliers..... first try they came out.
05 EX Cab Short
8 inch Fabtech
38 inch SSRs on 17x10 Centerlines(powdercoated)
SCT Innovative tunes
Banks CAI
Offroad MBRP Stainless 4.5 " and up pipe.
Auto Meter EGT, Fuel pressure, Trans Temp, Oil temp, water temp gauges.
Blue spring , bored 3 hole banjos.
ARP Studs
OEM Ford gaskets.
EGR Delete, cooler delete.
Bulletproof stand pipes
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
Innovative 48v FICM Performance flash.
RoCkfiSh363 is offline
