Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Drivetrain problems
Old 08-03-2008, 01:14 PM
dana60axle dana60axle is offline
Send a message via AIM to dana60axle
Unhappy powersteering?
i put a new pump on and hoses had the system flushed and bleed and i still have no brakes or steering the said the pump is making pressure what else could be wrong?
Old 08-12-2008, 12:33 AM
bigcountrysg bigcountrysg is online now
Countryboy Mechanic
Explain what is actually going on. You are being to brief with your discription for your problem.
Old 08-13-2008, 09:32 PM
u have to push really hard on the brakes and theres no power steering at all the shop i took it to said the pumps good they flushed the system and everything still doesnt work
Old 08-13-2008, 09:41 PM
Countryboy Mechanic
Brake booster may have failed. There for it may need replacing.
Being the engine does not create vacuum. The brake booster works off of hydraulic pressure from the powersteering pump. If the brake booster has failed that will cause your brake problem. Which may also be causing your powersteering problem.
Other then that I would look at your belt and make sure it is not slipping.
Old 08-13-2008, 09:44 PM
already checked the belt thats what i figured it was just wanted to make sure thats what it was before spending the money
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
