EGR delete cause 4x4 issues???? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-04-2013, 10:10 AM Thread Starter
Quoted: 9 Post(s)
My A/C has been going to defrost intermittently when 4x4 is engaged. I just had my EGR deleted and havent uploaded a tune to shut the EGR off. Will this cause my A/C to go to defrost when switched to 4x4???
2005 Dark Blue F-250 Harley Davidson 4x4. SCT Livewire TS, 4" Silverline TBE, Sinister intake elbow, Riff Raff turbo boots, Blue spring, 6.4 banjo bolts, Sinister coolant filter, Fleetguard OAT, IPR EGR delete, ARP studs.
1998 Dodge Viper GTS. Silver/Blue stripes 1 of 21: Corsa exhaust, high flow cats, K&N filters, smooth tubes
Invasivore is offline
post #2 of 3 Old 11-20-2013, 03:14 PM
Powerstroke Tech
whitestrikr21's Avatar
Quoted: 3 Post(s)
Garage
No check the vacuum lines on the 4x4 may have a leak since when 4x4 will open a vacuum solenoid to engage the auto hubs. The default blend door actuator position is defrost when vacuum is lost
03 F-350 Crew Cab short bed
6.0l
Arp studs
XDP Coolant filter
Sct Sf3- idp tunes
Silverline staintless turbo back 4"
XDP egr delete
whitestrikr21 is offline
post #3 of 3 Old 11-20-2013, 03:18 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
agree^^^^ Found this out when I did the coolant filter and forgot a single little vacuum line...
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
