4X4 suddenly won't work - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-03-2013, 08:25 AM Thread Starter
silverstroke2011's Avatar
I have a 2003 6.0 and recently my 4x4 quit working, i have the switch on the dash, the switch it itself dosent light up when i have the lights on? but the 4x4 indidcater light comes on on the cluster. the transfer case does ingauge cause i cant spin the shaft when I have it in 4hi but the frount wheels wont pull me? so idk wht it could be maybe i need new locking hubs?
silverstroke2011 is offline
post #2 of 11 Old 11-03-2013, 09:58 AM
6 L chevy eater's Avatar
Check your transfer case motor, get someone under the truck wen u put it in 4wd to make sure it's actually working. If not I think it's 3 0r 4 bolts that hold it on. Very easy fix
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #3 of 11 Old 11-03-2013, 10:06 AM
pizalm's Avatar
Try locking the hubs manually. Mine won't work off vacuum at the moment, 4x4 light comes on but the fronts won't spin unless manually locked.
pizalm is offline
post #4 of 11 Old 11-03-2013, 01:23 PM Thread Starter
Checked the motor it makes a vacuum sound? I know the one on my gasser buzzes when it engaues. And I tryed the manual setting, the half shaft turned but there was no pull from the front wheels.
post #5 of 11 Old 11-03-2013, 04:45 PM
If u have too take the motor off t case and visually look at while ingaugin the 4x4. U should be able to hear it turning tho. If that's not it then idk.
2004 F250 ccsb
post #6 of 11 Old 11-04-2013, 07:13 AM Thread Starter
I wish the labeling wouldn't have worn have so I could tell witch setting is which setting is which on the hub I'm hoping its something as simply as ones in manual and ones in auto
post #7 of 11 Old 11-04-2013, 07:35 AM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
99% sure your auto locking hub seals are bad.
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #8 of 11 Old 11-04-2013, 07:41 AM Thread Starter
How hard are they to replace? They say I got 4-6 inches of snow coming Tomarow..... ha
post #9 of 11 Old 11-04-2013, 07:49 AM
Winning DUHHH
Quoted: 8 Post(s)
Not hard, they're expensive to buy tho.
I recommend replacing with WARN manual lockers, and capping off the vacuum lines.
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
post #10 of 11 Old 11-04-2013, 03:37 PM Thread Starter
Are there any write ups on how to convert to warn hubs???
