lockouts - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-20-2013, 09:58 AM Thread Starter
lockouts
so I'm having problems with my lockouts. I have auto locking hubs and all that. well if I put it in 4x4 my hubs wont lock, but if I get out and manually lock them they will lock, and if I turn my hubs back to manual they will stay locked until I take it out of 4x4. Any ideas on what my problem might be? could it be that they jut need to be greased (which is what I'm hoping) or does it sound like bad lockouts??? thanks guys.
Iowa Diesel is offline
post #2 of 7 Old 10-20-2013, 10:15 AM
Pro fuzz's Avatar
Quoted: 29 Post(s)
Check vacuum lines going to hubs!! common on these rigs . Do a search on here lots of info about this !!!
2006 F350 KR cclb 155/stock full force powermax / WWII leveled carli 2.5 pintops 08&up full rear spring ouo 3link arms 36 toyo mt 4.30 yukon grizzly rear locker :yike
s:
New ride 2015 tow boss dpf & egr lost !!
Pro fuzz is online now
post #3 of 7 Old 10-20-2013, 10:23 AM Thread Starter
it doesn't seem like a vacuum leak since they stay locked even after I put it back in auto until I take it out of 4x4, so to me it seems it holds pressure once I lock em manually right?
03 f-250 6.0 fx4 auto, afe stage II, 4inch turbo back, 58v ficm, sct with innovative tunes, isspro fuel press, trans tep, boost, pyro, 3 inch leveling kit, egr delete, head studs,
post #4 of 7 Old 10-20-2013, 11:41 AM
Pro fuzz's Avatar
Quoted: 29 Post(s)
If it's vacuum related your heat or ac will default to the defrost no matter what setting u have it set on (floor,vent ect)
s:
post #5 of 7 Old 12-09-2013, 11:28 AM
Flooringit's Avatar
Quoted: 29 Post(s)
Good info. ^^^^ my hubs work sometimes they don't. I noticed yesturday my heat would switch to defrost all the sudden then would switch back a few minutes later. Was like having a ghost in the truck switching my heat. Now I know I need seals or have a vacuum leak. I have a clicking noise in drivers front wheel when going uphill in. 4wd. Never any other time. I got out and switched the hubs manually to see if I felt any grinding and hubs never sealed again
2007 outlaw.
sct x3
gearhead tunes srl
swamps 58volt ficm
php ficm programming
xd hoss machined face rims
with toyo mts 35x12.50x20
icon 4.5 lift
top gunz steering stabilzer
headstuds and egr delete coming soon
Flooringit is offline
post #6 of 7 Old 12-09-2013, 11:38 AM
allergic to hot weather
95and05's Avatar
Send a message via AIM to 95and05 Send a message via MSN to 95and05
Not if the lines or ports are plugged.
The defrost is affected by a faulty vacuum pump as well but the hubs have separate lines that can get plugged.
Also the vacuum ports are quite small and can be plugged at the hub end fairly easily.
Keith in Alaska (lovin it)
94 IDI
95 7.3 ex cab L/B 4X4 (D66 stage 1s 4" Turbo back 6637 air filter and bully dog chip)
05 6.0 Excursion 4X4 (stock)
10 6.4 F350SRW CCLB manual trans (stock)
95and05 is offline
post #7 of 7 Old 12-09-2013, 11:39 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
OP, since yours stays locked after manually engaging them and then turning back to Auto, you might have a weak vacuum pump. Just a thought
dhanna6powerstroke is offline
