HELP!! 06 F350 shakes while braking over 45MPH - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-28-2013, 07:44 PM Thread Starter
06/powerstroker's Avatar
I need some help i have a 06 F350 crew cab long bed 4x4 with a 8 in fabtech lift and 37x13.50r20 , when driving above 45mph and i apply the brakes i get a shake in the steering wheel, i cant figure out whats causing it i have replaced all steering components except tie rod end and ball joints. i have had the front rotors turned. any help in the right direction would be great cause at this point im lost .
06/powerstroker is offline
post #2 of 9 Old 09-30-2013, 02:20 PM
Joeshu1000's Avatar
I would lean towards warped rotors even though I see you had them turned. Do you know if you have a sticky caliper up front? Also, I would have the tires balanced, unlikely but possible.
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Rudy's Cold Air Intake
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
post #3 of 9 Old 09-30-2013, 03:51 PM Thread Starter
I think im going to pull front rotors off a buddies truck for a test run and see if that fixes it and go from there.
post #4 of 9 Old 10-05-2013, 04:25 PM Thread Starter
Well I figured it out, it was the caliper slide pins, one on each side of the front were rusted to the caliper bracket.
post #5 of 9 Old 10-05-2013, 05:31 PM
Joeshu1000's Avatar
Glad you got it fixed.
Joe
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Updated STC Fitting
6.4L Banjo Bolts
PHP Ficm Tuner
post #6 of 9 Old 11-17-2013, 02:23 PM Thread Starter
OK shake is back anyone have any ideas
post #7 of 9 Old 11-17-2013, 03:24 PM
Lightbulb is offline
post #8 of 9 Old 11-17-2013, 03:55 PM Thread Starter
ill have to look into that.
post #9 of 9 Old 03-29-2014, 07:05 PM Thread Starter
Problem fixed ended up being the passenger front abs wheel speed sensor. Installed a new one and it fixed the shake.
