Sway Bar Bushings - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-24-2013, 10:55 PM Thread Starter
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
Sway Bar Bushings
So i have the Ford Part Number but i want to go with a more stout Bushing than OEM... can anyone tell me the Diameter of my sway bar.. i Mic'd it and it came out to just a lil below 7/8th Inch. the Part Number is 5c3z-5484-ca
Thank You!
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #2 of 9 Old 09-24-2013, 11:36 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
If you got the extra money... I'd get the Hellwig sway bar. It's works a lot better than factory and is just under $200. The kit number was 7676 I believe but it uses the factory end links so upgraded bushing would still be needed. When we upgraded my dads we just used the Hellwig sway bar and he could tell right away when pulling his camp trailer.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 9 Old 09-24-2013, 11:43 PM Thread Starter
Smoke Eater
awesome i guess i should have been specific and mentioned for the front... however i may just do the total upgrade for front and rear
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
fdchief is offline
post #4 of 9 Old 09-24-2013, 11:47 PM
Quoted: 8 Post(s)
He did both of his and he said it was worth every penny! I'm getting some as soon as I get a camp trailer for myself. The rear was more expensive but can't remember how much. Hellwig probably offers upgraded bushing but for sure.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 9 Old 09-24-2013, 11:51 PM
Quoted: 8 Post(s)
Here is a link I just found for hellwig products...
Hellwig Sway bars
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 9 Old 09-25-2013, 02:01 AM Thread Starter
Smoke Eater
Hellwig Sway bars
awesome ty!
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
fdchief is offline
post #7 of 9 Old 09-25-2013, 12:21 PM
Quoted: 50 Post(s)
Originally Posted by fdchief View Post
awesome ty!
Chief-
Just a word of caution on going with the Hellwig #7676 front bar. I spent months working with Hellwig to get it to work and it never did. It also rubbed on the inside of the tires at full lock. When I finally pressed Hellwig on it they said that they never tested it with the OEM 20" wheels - just the 17s & 18s. They then said it must be aftermarket tires that are too wide, so I had to inform them that I am still running 275/65/20s. I then shipped them my OEM front bar so they could see how different it was from their #7676, and they then used my OEM bar to custom bend me a new bar. It arrived in about 3 weeks and it was worse than the first one! The right and left ends we're not even bent to the sample angles, and it wouldn't even bolt up.
Then someone suggested that the OEM front bar on the 08 and newer trucks would bolt on and is much thicker than the 05-07 bar. Well, it is thicker - but it wont bolt up. The bar mounts differently on the 08 and newer trucks.
So, I am now back with the OEM 05-07 front bar. That being said, I do have the Hellwig rear bar and it works great.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #8 of 9 Old 09-25-2013, 07:25 PM Thread Starter
Smoke Eater
Originally Posted by skanj0 View Post
Chief-
Good to know... i may just look at finding some good poly bushings in that case
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
fdchief is offline
post #9 of 9 Old 09-25-2013, 07:27 PM
Quoted: 8 Post(s)
Chief-
Good info... This really can help those you have 20's!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
