06 F-250 intermitment gear grinds and clunking noise. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-12-2013, 11:43 PM Thread Starter
Hi guys,
I'm stump on what's going on with my rig a few days ago after I was at a dead stop to make a sharp turn I heard a slight gear grind followed by a loud clunk/bang for a split second before the truck was able to move the noise was hard to tell where it was coming from it almost sounded like its either coming from the differential or the transmission but its hard to tell because it doesn't happen all the time. Any ideas or suggestions on how to fix it is greatly appreciated.
Thanks in advance,
Doombugie
2006 F-250 6.0L Powerstroke, K&N intake with S&B filter, 3.5" - 5inch Mbrp Cat back exhaust with muffler delete pipe, Garret Powermax, Performance Machine Coolant filter, SCT Livewire w/Innovative Diesel Xtreme tune, High idle mod, Glowshift gauges Egt, oil temp, fuel pressure. 2.5" leveling kit, 35X12.50R17 Nitto Trail Grappler, Rancho Dual Steering Stabilizer, Rancho 9000XL Shocks.
doombugie is offline
post #2 of 10 Old 09-12-2013, 11:48 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Have you checked your U-joints at the driveline and front axles if you had the hubs engaged
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 10 Old 09-13-2013, 12:01 AM Thread Starter
When the problem occurs the 4wd was not engaged nor was the hubs. But I'll have a look at the driveline tomorrow.
post #4 of 10 Old 09-13-2013, 12:04 AM
Quoted: 8 Post(s)
Do your automatic hubs work? I know if your hubs aren't working properly and you need to put them in the lock position for 4x4 that once you unlock them they will still stay in the locked position. Only way to unlock a auto hub that isn't engaging correctly is to turn the hubs from lock to auto three times... Back and forth stopping on auto.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 10 Old 09-13-2013, 12:08 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
i would think u joints. what cab configuration are you CCLB ECSB basically do you have a carrier bearing or not. when checking joint put truck in Neutral roll a bit then put on Ebrake while your rolling once yours stopped throw it back in park and check the u joints and carrier bearing.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #6 of 10 Old 09-13-2013, 12:17 AM Thread Starter
I believe its a ECLB, so by rolling it back and putting it in park am I looking for any movement on the driveline ?
post #7 of 10 Old 09-13-2013, 12:31 AM
Quoted: 8 Post(s)
ECLB extended cab long bed (rear doors are suicide type)... Just incase you weren't sure on the abbreviation. I'm pretty sure mytractorsexy is having you verify the trans is holding the u-joints in a bind...
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #8 of 10 Old 09-14-2013, 11:06 AM Thread Starter
After I rolled the truck forward I don't see any binding in the U-joint or any side to side movement. But when I jack the rear end of the truck up the driveshaft spins freely followed by a loud clunk before the wheel starts to spin could this be a diff problem ? It sometime happens when I'm making a turn.
post #9 of 10 Old 09-14-2013, 11:41 AM
Quoted: 8 Post(s)
Possibly a problem in the differential housing... When is the last time you changed out your differential oil?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #10 of 10 Old 09-14-2013, 11:56 AM Thread Starter
I haven't changed it since I bought the truck. But I did notice some diff oil coming out of the pinion seal.
