'06 F250 new tires now suspension issues? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-07-2013, 01:20 PM Thread Starter
Hi, everyone.
I am in need of some advise about suspension and drivability.
I am driving a '06 F250 CC Lariat, LWB, 6.0 PS, 4x4, all stock, 114.000mls.
Here is the story:
The original Goodyear Wrangler ATS (275/65-20) were worn and I got a set of Firestone Destination AT LTS (same size). These worked
fine on an older Chevy I owned years ago.
Since I got these tires on the truck the backend feels kinda squirrly, weaving around way more then usual when I move the steering
wheel around a few time, at speeds greater than 35mph. I went back to Tiresplus and they checked the alignment again, all bushings,
struts, axles and couldnt find anything worn or loose. Test drove it again and it was still doing it. Then they said it might be the
tires. They ordered Bridgestone Dueller Revo2 and put them on the rear axle (as a test). That didn not change a thing.
So they swapped front and rear which made it worse. Now I am back on all Firestone. They checked the alignment again. Then replaced
the steering damper. Still not any better. The store manager and a teck both agreed that it rolls more than it should and feels
weird, but they seem to think it is the front axle.
I stopped by a shop in town and the tech test drove it and agrees is feels different. He suggested to replace the shocks due to high
milage. He also said that new tires may have softer side walls and that could result in a squirrly (rear end) feeling.
Again for two days the tire store has been working on it and has no idea (said the store manager) what's wrong. I offered to replace
the shocks. I put some Bilstein Shocks on it. Rides better but still has a feeling like the backend is loose.
Neither store can seem to find any worn bushings, struts or anything that may cause this. It has never done that with the original
Wranglers. Could it be that this truch is that picky and really wants the Wranglers??
Any advice, pointers, help or suggestions are appreciated. Maybe there is someone out there that had the same problem, hopefully a
fix, too.
Thanks in advance
FrankEGD
frankegd is offline
post #2 of 10 Old 09-07-2013, 01:43 PM
Quoted: 58 Post(s)
Originally Posted by frankegd View Post
Hi, everyone.
Here is the story:
fix, too.
Thanks in advance
FrankEGD
A couple of things to offer you:
1) all new tires feel squirly for the first 300 to 500 miles. It's very common. Some say its due to the mold release agent used in the manufacturing process.
2) check the air pressure. Running unloaded I would be at 65 psi front and 55 psi rear. Too high or too low will affect the handling.
3) the Goodyear AT/S tires that came on these trucks were pretty crappy, IMO. I dumped mine early and installed Toyo MTs in the same size (also the size you have). I love them and they handle great for a mud tire. Currently have 35K on them and should get another 8K to 10K before they go to the shredder.
Good Luck and report back with your findings.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 10 Old 09-08-2013, 11:34 AM Thread Starter
Ok I never had an issue (squirly) like that with new tires, neither on a truck or car. But I've been told that this might be the case here. I tried lowering the tire pressure and that did not change it. Someone else suggested trackbar bushing. Did that, also nothing.
So, now I'll wait what the tire store comes up with. I am just afraid that if I keep the tires and if in about 500 mls they won't change that they might not take them back.
Thank you
FrankEGD
frankegd is offline
post #4 of 10 Old 09-08-2013, 01:24 PM
Heavy_GD's Avatar
Quoted: 1579 Post(s)
Feedback Score: 3 reviews
Whats the PSI?
GD
Heavy_GD is offline
post #5 of 10 Old 09-08-2013, 01:49 PM
Term3's Avatar
Quoted: 2 Post(s)
Originally Posted by Heavy_GD View Post
Whats the PSI?
Pounds per square inch
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 10 Old 09-08-2013, 02:08 PM
Heavy_GD's Avatar
grassy a$$, although missing an apostrophe the "s" would lead you to assume it reads "what is" and including "the" directs you to wanting information regarding the PSI... now had I forgot "the" and went with "whats PSI" you would be on the right track with the witty response.
Now that we are good and I got a free post, he said he lowered the PSI so I was inquiring on the new number.
GD
Heavy_GD is offline
post #7 of 10 Old 09-09-2013, 02:29 PM Thread Starter
Tried 65, 70 and 75psi all around. None made a difference...
Thx
FrankEGD
frankegd is offline
post #8 of 10 Old 09-12-2013, 07:14 PM Thread Starter
Ok, so far I drove about 300mls on the new tires. Today I also replaced the trackbar ball joint. The first test drive shows some signs of improvement. I think it might be from the tires and the fact that thay need to get worn in a bit, like others mentioned earlier.
I will give it a little bit more but I think I migth be ok.
Thanks for all the info and every post regarding this issue.
FrankEGD
frankegd is offline
post #9 of 10 Old 09-13-2013, 05:40 AM
Quoted: 58 Post(s)
FrankEGD
Glad things are improving!
Carli Radius Arms
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #10 of 10 Old 11-01-2013, 09:09 AM
snobdds's Avatar
Quoted: 10 Post(s)
What's the new tire load range?
snobdds is offline
