4wd not workin, help fast Im stuck - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 22 Old 09-04-2013, 05:28 PM Thread Starter
Texas Proud
charlie.thomas's Avatar
So I'm stuck an my 4wd isnt workin. Transfer case is but auto hubs aren't. Put it in 4wd and air goes from panel to defrost, where could the vacuum leak be?
"Feel the Fear and Do It Anyway"
2007 F250 King Ranch
Alligator Performance EGR Delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
4" Turbo back straight exhaust
SCT Livewire TS tuned by the best, "Tony Wildman"
New block bored .020" over
New heads ported, polished, and decked
ARP Head studs
And other goodies
Lifted on 35" Toyo Open Country MT
charlie.thomas is offline
post #2 of 22 Old 09-04-2013, 05:41 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Why aren't your hubs auto? Did you change them? Anyways I'm sure here is a hose that's disconnected or broke somewhere between your vacuum pump and front spindles.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 22 Old 09-04-2013, 05:45 PM Thread Starter
Texas Proud
I didn't change them but they are auto. Auto bein they are vacuum drum an my air goes from dash to defrost when I try to use 4wd
5" AFE air intake
Blue Spring Mod
High Idle Mod
ARP Head studs
And other goodies
post #4 of 22 Old 09-04-2013, 05:46 PM
Get out and lock them. Mine has a leak some where so I just lock them by hand when needed.
1992 F250 4x4 260K 7.3 IDI hypertech turbo SOLD
1997 F250 cc 4x4 now with a 96 psd, zf5 diy air filter & tw 6 pos, Dana 60 comingsoon 1995 f350 cc 295k 7.3 zf42 the doner for my 97 Donated & dismantled
slandry786 is offline
post #5 of 22 Old 09-04-2013, 05:46 PM Thread Starter
Texas Proud
Driven not drum lol
5" AFE air intake
Blue Spring Mod
High Idle Mod
ARP Head studs
And other goodies
post #6 of 22 Old 09-04-2013, 05:47 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
probably at the vacume lines to the hubs themselves. that's the most common place. you should be able to lock your hubs and get out. locking them bypasses the vacuum hubs.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #7 of 22 Old 09-04-2013, 05:47 PM Thread Starter
Texas Proud
I can't bc of the center caps. They worked just over a week ago too
5" AFE air intake
Blue Spring Mod
High Idle Mod
ARP Head studs
And other goodies
post #8 of 22 Old 09-04-2013, 05:49 PM Thread Starter
Texas Proud
What would make it go from panel to defrost?
5" AFE air intake
Blue Spring Mod
High Idle Mod
ARP Head studs
And other goodies
post #9 of 22 Old 09-04-2013, 05:51 PM
Lol might have to bust a center cap if you want to get out
Sent from AutoGuide.com App
2012 F250- 4.5in. lift, 24x12 rockstar II's painted tuxedo black, 37x13.50x24 M16's, KEM race tunes, 5in. exhaust, and much more.
DillonC is offline
post #10 of 22 Old 09-04-2013, 05:53 PM
RetiredFD's Avatar
You need to lock them manually. Pop a cap off.
- Chris
2006 F250 CCSB Lariat
RetiredFD is offline
