10.50 Gear Problem - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-02-2013, 02:11 PM Thread Starter
585Amarillo's Avatar
10.50 Gear Problem
I switched my 3.73 gears to 4.56 on the LSD and I'm trying to set up the pinion shims and carrier shims and the pinion is hitting the carrier case. I'M trying to find out what I'm doing wrong here any helps is welcome.
K&N Intake
MBRP 4" Turboback
Silverline 6" Black Aussie Stacks
Zoodad Mod
Ford Updated parts
BPD FICM
Blue Fuel Pressure Spring
ARP Head-studs
Stock Injectors?
AirDog 165 Fuel pump
EGR Delete
SCT Custom Tuner By Inovative Diesel 5 tunes
10" Lift
37" Toyo Open Country M/T
4.56 Gears
18" XD Thump Black Wheels
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
Glowshift Gauges Trans.Temp., EGT, Fuel Pressure
585Amarillo is offline
post #2 of 5 Old 09-02-2013, 04:38 PM
Quoted: 818 Post(s)
The pinion bearings have a slight press fit even without the crush sleeve installed. So you may not have the pinion seated all the way. Sometimes people will buy a setup bearing to get your correct gear mesh pattern. Once you get that set then that's when they put on the bearing that's going to be in service. But the setup bearing isn't necessary, just makes it a bit easier.
Corey@CNCFAB is offline
post #3 of 5 Old 09-02-2013, 06:23 PM Thread Starter
Do you know what the pre-load is on the pinion nut?
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #4 of 5 Old 09-03-2013, 12:43 AM
Quoted: 818 Post(s)
After everything is set up and the final torque down is done with the crush sleeve its somewhere between 15-20in/lbs of rotational resistance iirc.
post #5 of 5 Old 09-03-2013, 01:25 AM Thread Starter
ill try to mess with it to day thank you
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
