Dome light not working - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-24-2013, 12:00 PM Thread Starter
05f250harley's Avatar
I changed my dome lights to leds. When I was changing the front the center light popped. The two outside lights work just not the center lights. I thought I blew a fuse but they were all good. I tried different lights that I know were good and nothing. Any ideas?
05 Harley Davison Edition Arp head studs, SCT livewire TS, 03 turbo, PMM egr delete, PMM coolant filter, afe cai, blue spring, 6.4 banjo bolts, updated stc, standpipes and dummy plugs, 4" exhaust with no cat and no muffler
03 RCSB 205/100 warren injectors, BW s366, Lots of supporting mods to come
05f250harley is offline
post #2 of 5 Old 09-14-2013, 12:04 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Unfortionatly it sounds like you fired a wire. Might check the harness going into the dome light housing just to make sure. You could find the wire under the door sill plate and see if it has power while the door is open. I think it is blue/white stripe...not 100% sure though (been while since I wired my exterior door ajar lights.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 5 Old 09-14-2013, 12:05 AM
Quoted: 8 Post(s)
FYI, you'd probably get more help in the electrical section rather the drivetrain problem section.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #4 of 5 Old 09-14-2013, 05:45 AM
510guy's Avatar
did you check all the fuses, or just the dome light? i ask because in the book it says nothing about the dome light on the fuse i have out to make mine not come on. i think its fuse 29, 10 amp bottom row in the box under the steering wheel.
2006 F350 Crew Cab Dually 6.0 PSD 6 spd, ARP, IPR Gen 2 with up pipe, BD Diesel boot kit with metal cold side intercooler tube
2008 f350 Reg cab SRW flat deck 5.4l for work
510guy is offline
post #5 of 5 Old 09-14-2013, 02:42 PM
Master_Blaster's Avatar
does your under hood lamp work?
04' 350SRW SCT tuner, 6 inch Rough country lift, 37x13.5R20 Nitto Terra Grappler, 5" stacks
Master_Blaster is offline
