Hopping feeling at 70 - 80 km/h - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-15-2013, 09:02 AM Thread Starter
07lariat's Avatar
Truck is a 2007 F250 Lariat 4X4. Over the past several months I have been getting an intermittent hopping feeling from the rear end between 70 - 80 km/h. Thought it may have been a balancing issue so had the tires all road force balanced but still the same issue. Rear end bearings were done in January. Anyone with similar issues?
Sent from AutoGuide.com App
2007 Lariat FX4 Crew Cab
275/75/18 Goodyear Duratracs
9000 lb Warn Front Hitch
08 Aluminum rear diff cover
HID headlights
Edge CTS Insight
SCT SF3 flash tuner
Blue spring mod
6.4 banjo bolts
high idle mod
07lariat is offline
post #2 of 8 Old 08-22-2013, 12:43 PM
having same issue with customers 05. New shocks, diff bearings, wheel bearings, tires balanced. Tires are toyo AT's.
Black 2004 F-250 Sport Crew Short, 4" hanger drop, dual bilstein, 35" KM2's, DP 1 piece block w/.75" u-bolts. Swamp's 58V FICM, SCT w/SLR.
Dunks Performance is offline
post #3 of 8 Old 08-25-2013, 08:58 PM
Deer Creek's Avatar
Quoted: 51 Post(s)
Is it hopping or skipping? FICM and/or injector failure can do the same thing. Just a thought. Before I replaced my FICM I would get what felt like a hop between 55 - 65 MPH. Turned out my FICM was failing. Might want to check it out and it's free so what can it hurt? Good luck and let us know what you find out.
Ryan
Deer Creek Farm
Carthage, NC. 28327
2004 F250 4X4 6.0 Diesel "War Wagon"
SRW Crew Cab Long Bed Pushing 305,000 Miles
Running 5w-40 T6 with RevX
FICM PHP Eco Tune
Blue Spring MOD
Warren 175/30 Injectors
EGR Deleted & Studded
Dieselsite Adrenaline HPOP
Coolant Filtration System
MBRP 4" Turbo Back Straight Pipe
Bullet Proof Diesel Water Pump
Ranch Hand's Legend Front & Rear Bumpers
2" Rough Country Lift
SCT X4 Tuner
Nitto Terra Grapler 285/75/16s
Deer Creek is offline
post #4 of 8 Old 08-26-2013, 06:22 AM Thread Starter
07lariat's Avatar
I wondered the same thing but I've found that if I shift into neutral and coast at the same speed that the hopping feeling is still there.
HID headlights
Edge CTS Insight
SCT SF3 flash tuner
Blue spring mod
6.4 banjo bolts
high idle mod
07lariat is offline
post #5 of 8 Old 09-13-2013, 11:59 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
The dreaded Super Duty vibration... Lots of people complain about this, never heard of a complete 100% cure. Some brand new trucks do the same thing.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #6 of 8 Old 06-27-2014, 02:26 PM
supposedly this is due to the wide wheel base causing a hop feeling...
Vibration/Hop at 40-48 MPH, Trucks with Trailer Hitch:
Some 2005-07 F-Super Duty trucks with long wheel base (over 156") may exhibit what is described as a hop on smooth or coarse road surfaces. Although Ford considers this to be characteristic of trucks with a GVW of over 8500 pounds, some drivers may be more sensitive to the condition. There is a damper kit (P/N 5C3Z-5D008-A) available to correct the hop under the described conditions. It will not correct shimmy, harsh ride or vibration after hitting bumps. TSB #07-5-11.
dizzle42187 is offline
post #7 of 8 Old 07-03-2014, 08:23 AM Thread Starter
07lariat's Avatar
Since I originally posted this question I've noticed that the hopping isn't constant. It will hop for a day or two then it will smooth out for a few days. Could shocks be the issue??
HID headlights
Edge CTS Insight
SCT SF3 flash tuner
Blue spring mod
6.4 banjo bolts
high idle mod
07lariat is offline
post #8 of 8 Old 08-04-2014, 03:27 PM
bigbob71's Avatar
Garage
for me it's the concrete freeway and only in certain spots....no hoppy on asphalt.
bigbob71 is offline
