Brake Bleeder Saga - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-07-2013, 02:28 AM Thread Starter
Quoted: 2 Post(s)
Brake Bleeder Saga
Well here is a little tid bit I learned the hard way. A lot of people will probably read this and think no chit, but hey it took me a while to come to this conclusion. The whole mess started three years ago when I needed brake calipers/pads/discs in the rear and was short on time, so I had the dealership do them. I paid my left leg, got in my truck everything was great until last week.
My truck '07 f250 sits an awful lot due to work and having a company vehicle, so lucky me the right rear brake locked up on me. No biggie I just stopped at my local Advanced Auto on my way home from Texas, got a replacement some DOT 3 and figured life would be great. While bleeding I kept thinking to myself man this looks weird, but the caliper looked like and was installed the same way the other side was which was done at the dealer ship.
Enter soft pedal syndrome. So after bleeding no kidding a gallon of fluid from all corners with a vacuum bleeder and still having the same problem, time to dig deeper. I will spare the details as this is already getting to be a long read (if anyone has made it this far) but, new parts included: 1 master cylinder, 1 break fluid pressure sensor which I broke, 1 hydroboost , 1 rear caliper from autozone.
The solution, BRAKE BLEEDER SCREWS ALWAYS GO AT THE TOP. As luck would have it the dealership had put the calipers on reverse, I copied them not thinking clearly, and both Advance and Autozone had given me the wrong side as far as I can tell.
So I felt pretty dumb especially after the years spent in the gas patch explaining to people how gas or air rises up through fluid. (Easy concept often overlooked as I did. If you don't believe me fill your bathtub up and fart and tell me where the bubbles go.)
Moral of the story, no matter how hard you try a caliper will never bleed out if the bleeder is on the bottom.
oilfieldtrash15 is offline
post #2 of 5 Old 08-07-2013, 11:32 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
Man, thanks for sparing someone the time and energy from having to go through that ordeal like you did... BTW, I was laughing about the fart bubble illustration...
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 5 Old 08-07-2013, 11:36 AM
asian195's Avatar
Quoted: 2 Post(s)
Live and learn, right? It's unfortunate thought, that the dealer put them in backwards..
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #4 of 5 Old 08-07-2013, 11:51 AM Thread Starter
Quoted: 2 Post(s)
Live and learn is pretty much where I am at. I figured I would post this as I couldn't find anything on this site and hopefully it well help someone out. On the bright side though, I can rest assured that all brake fluid in my system is brand new and hopefully prevents this from returning so soon due to moisture in it.
post #5 of 5 Old 08-07-2013, 11:56 AM Thread Starter
Quoted: 2 Post(s)
And I didn't mean to bash dealer techs as I have seen from posts on this site that prove there are some very good ones. But, whoever did this graduated suma caude done flunky outie, and I committed lemming suicide and followed.
