2006 F250 Front Driveshaft Rattle - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-06-2013, 03:43 PM Thread Starter
My Front drive shaft is rattling at low speeds. I checked the u-joints and they seem fine. But when I spin the shaft you can here something rattling inside the shaft tube.
Anyone have an idea what could be loose on the inside of the shaft? Is it possible to fix it? Or do I just need to replace it?
Thanks
Richard
RICHE is offline
post #2 of 5 Old 09-05-2013, 09:44 AM Thread Starter
If anyone ever comes across this post, It was a cap at the end of the slip yoke (inside the front shaft). Somehow it came loose and was rolling around in the drive shaft tube.
I was able to get the local drive shaft repair place to cut it open, weld the cap back in place and weld the slip yoke back on.
RICHE is offline
post #3 of 5 Old 09-07-2013, 08:15 AM
Quoted: 58 Post(s)
Wow. Never heard of that problem. Thanks for posting the resolution. Many folks never do.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #4 of 5 Old 10-14-2014, 06:41 AM
roverdisc98's Avatar
oddly enough, I'm having the same problem. It sounds like a rock or something is INSIDE my front shaft. I believe i'll remove it, cut it open, hopefully find something rattling around, and then weld it back up.
Pretty strange if something is inside the sealed shaft
2006 F350 Crew Cab LWB SW
roverdisc98 is offline
post #5 of 5 Old 10-15-2014, 11:30 AM
the little cap had come off inside the shaft. cut open, removed, re-balanced and installed. problem solved
