Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Drivetrain problems
Old 10-14-2006, 09:24 AM
scvadnais scvadnais is offline
bad brakes
have a 03 F250 that I just bought and when I apply the breaks they become soft after holding the peadle down. I brought into a dealership and they said it is normal. This does not sound correct to me. it almost feels like a bad master cylinder has any one else had this problem and how did you fix it?
Old 10-14-2006, 10:26 AM
dercody dercody is offline
Desert Storm Vet
Send a message via Yahoo to dercody
no, the dealer is incorrect, mine doesnt act like that, when i press the brake pedal, my truck stops!! it does sound a bit like a bad master cylinder, like fluid would be bypassing the diaphram. i have had that situation before. not in my truck, but other vehicles.
Old 10-14-2006, 10:29 AM
slammedSI slammedSI is offline
A cow says , Moooo
bad mastercylinder!
Old 10-14-2006, 03:09 PM
mschn99 mschn99 is offline
Banished
All depends on what your are actually describing. If your talking about the "spongy" feel in the pedal even though it stops right, thats just the nature of hydroboost......it feels considerably different on pedal application than a vacume boost system
If the pedal "goes away" you have either glazed over the pads and rotors pretty bad or you have a master cylender bleeding by.....
Old 08-09-2007, 07:10 AM
jimmer818 jimmer818 is offline
Send a message via MSN to jimmer818 Send a message via Yahoo to jimmer818
I know it’s an old topic, my truck (2003 6.0 F250 CC SB) is doing the same exact thing, I have replaced the calipers, rotors (went with power slot), pads (hawk pads), Lines, & master cylinder and the breaks still feel the same. It did it when it only had a 4” lift on 35”s now it has a 16” lift on 42”s with all the new parts it’s the same as it was before, I work at valley spring service in phoenix & drive a lot of lifted trucks (on test drives) and notice they stop way better. What else it could be?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
