Ball Joints? Steering Gear (replaced)! Still loose! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-31-2013, 12:58 PM Thread Starter
neattouch648's Avatar
Hey Guys...
I know there are a lot of posts about this and i've read through most of them but i can't seem to find the exact answer...
I have an 06 250 and it has extremely loose steering. I messed around with all the front end parts and found nothing loose or clicking. The steering gear seemed to have some play in it when i fiddled with it so I replaced the steering gear (it was leaking pretty good too so it needed to be done) After replacing this my steering is a little bit tighter but not much.
about a year ago i wanted to get the truck aligned and they told me they couldn't do it because my ball joints were bad. While taking the truck apart I noticed that nothing seemed loose. Even jacked up I can't get the front tires to move up or down or even side to side. Can my ball joints still be bad?
What should my next step be?
Thanks for all the help!!
2006 F250 SRW CCSB 4X4
1997 F250 SRW SCLB
neattouch648 is offline
post #2 of 8 Old 07-31-2013, 01:02 PM
Is your truck lifted at all?
Sent from AutoGuide.com App
2005 CCSB
4" Turbo back straight pipe,AFE intake,Coolant filter,
ELC coolant,Upgraded blue spring,140amp alternator,
EGT and fuel pressure gauges (all other monitoring via Torque Pro),2" leveling kit on 305/55/20,N-Fab step bars,Brush guard,Ranch Hand rear bumper,Jason topper,Limo tint,5000k HID's, IDP tunes
Dozer FX4 is offline
post #3 of 8 Old 07-31-2013, 01:51 PM Thread Starter
Its Leveled, but not lifted. I was just toying with it. Prying on the wheels to try and move the ball joints. It seems my passenger side upper ball joint is broken...I'm going to do those next I think.
1997 F250 SRW SCLB
post #4 of 8 Old 08-20-2013, 06:20 PM
colonel angus's Avatar
Quoted: 2 Post(s)
If you were told your ball joints were bad a year ago and you confirmed one is now broken, how did you think they would get better?
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #5 of 8 Old 08-20-2013, 06:22 PM Thread Starter
After I was told it was broken, i took it home to replace them, however wasn't able to move the wheel at all, not even with pry-bars. In all experiences I have ever had with ball joints, you could determine they were broken by moving the wheel or at least prying on it. When I couldn't I decided not to take everything apart since they seemed fine. I replaced them last week and still have steering play.
I didn't "think they would get better" but thanks for the sarcasm...
1997 F250 SRW SCLB
post #6 of 8 Old 08-20-2013, 06:28 PM
Did you watch your steering parts with someone else moving the wheel? If those are tight, get a pry bar on the suspension bushings and see if those are loose.
Hauser is offline
post #7 of 8 Old 08-20-2013, 06:43 PM
Quoted: 861 Post(s)
Feedback Score: 3 reviews
Are your bushings in good shape in your trailing arms?
Corey@CNCFAB is offline
post #8 of 8 Old 09-14-2013, 12:20 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Have someone turn the wheel as you watch both the steering shaft and the pitman arm. If there is movement being lost inside the steering box (steering shaft moves but pitman arm doesn't) then the steering box just needs adjustment. Look on top of the steering box and you'll see a locking nut in the middle. Use a 5/8 open ended wrench (I think) and loosen it first, then hold the threaded rod with an Allen wrench and loosen the nut about 45* degrees (1/4 turn) and tighten the Allen head down until it stops then tighten the nut with the socket and recheck for play. If there is still play but its getting better, turn the nut again another 1/4 turn. Don't turn the Allen head and locking nut to far or you could WILL damage the steering box. I would take the truck for a short test drive before re-adjusting because its serious chit if you go to far! Be careful and use this information at your own risk!!!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
