Rear Diff Question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-26-2013, 09:07 PM Thread Starter
paintballbryce's Avatar
Rear Diff Question
Hi there,
Did my first pull tonight, and it didn't turn out so good. My left rear tire didn't have much power, and my right rear tire was full of mud and dirt, as well as both front, but my left rear was dry, and looked clean. I talked to a mechanic and he said it may just need to have the diff fluid changed, any other opinions on what it could be? I need to get this fixed within the next week hopefully so I can hook again! Only pulled 135, because I got sucked to the right side too far.
Thanks guys, any input is greatly appreciated.
2006 F250 Bulletproofed - SOLD
2008 F350 King Ranch
Stock for now
paintballbryce is offline
post #2 of 11 Old 07-27-2013, 12:29 AM
JSchuricht's Avatar
Sounds like you need a locker.
JSchuricht is offline
post #3 of 11 Old 07-27-2013, 01:54 AM
alaskan155's Avatar
Quoted: 60 Post(s)
+1
if you have a limited slip in the rear you are just burning the clutch packs up
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #4 of 11 Old 07-27-2013, 02:01 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
ya the stock limited slip unit definately leaves room for improvement.
the right tire spins great the left rear usually does next to nothing lol
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 11 Old 07-27-2013, 03:53 AM Thread Starter
Okay, and what is a good brand to run that won't kill the bank? Just got up and need to get this done asap! Are they hard to do in a 06? Stock rear end as far as im aware!
Stock for now
post #6 of 11 Old 07-27-2013, 05:10 AM
gotta_gofast's Avatar
Quoted: 61 Post(s)
You're mechanic suggested a fluid change would fix it?
If you daily drive your truck you may want to consider a selectable locker, one that you can control when it locks both tires together. ARB makes a great product. "Auto" lockers will be cheaper but won't have the road manners an open or limited slip would have. Some people don't even notice and others can't stand the auto lockers constant engagement/disengagement (which could be a result of inconsistent tire pressure or tire wear). Either way, if you have to ask how hard it is to install... you should probably leave this job to a reputable shop or if you have a buddy with experience setting up gears to shadow you the first time.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #7 of 11 Old 07-27-2013, 05:41 AM Thread Starter
Yes, He is a diesel mechanic for diesel doctor. He said its common is 6.0Ls for the rear diff fluid to be bad. Don't know when it was changed last. I will be using it as a daily drive and a pull truck. I have the tools and the means to do it, just not sure if it was really hard in the 06 or not, hoping it would be easy.
Thanks!
Stock for now
post #8 of 11 Old 08-03-2013, 04:07 AM
Thanks!
Without sounding like an a hole your diesel mechanic should stick to the engines. There is no amount of diff fluid changing that is going to increase the amount of material on your frictions(you have steels and frictions) in your clutch packs. That was one of the dumbests things i have ever heard. As the material wears off the frictions the ability to engage both axles drops. The cheap way is to rebuild the clutch packs and put an extra friction in on each side( in place of a steel). Its still not going to last forever but its a poor mans locker
2006 F250 Lariat Bulletproofed
2006 F350 XLT bulletproofed SOLD
1983 Mustang GT 410/C4 SOLD
MustangSmitty is offline
post #9 of 11 Old 08-05-2013, 09:40 AM
Quoted: 57 Post(s)
Without more context from the mechanic it's hard to know what he thought the oil change would solve. That being said, it's not uncommon to have the OEM limited slip in these trucks begin working better after a fluid change. The reason being is that the factory fill usually has too much limited slip additive so people dont complain about the truck handling funky around corners, noise from the rear end, or barking the inside tire during sharp slow speed turns. Remember many trucks are used lightly and most wouldnt know if their LS was working or not.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #10 of 11 Old 08-05-2013, 05:42 PM
When asking for recommendations about a differential that won't break the bank, a selectable locker doesn't qualify in my opinion. You're looking at about a grand for an ARB. Ford Sterling 10.5"
The clutches in a Trac-Lock are consumables, I would get a repack kit from Randy's and get to work, it's not that hard. True Tracs are rumored to be good but I hate mine. The fact is, I wish I would have spent the extra money on a Detroit Locker and been done with it. These trucks are long enough, wide enough, and heavy enough that you probably wouldn't know it was there in normal driving. I have one in a 14 bolt in a half ton with 38s, it's fine.
I recommend doing a clutch pack set, then shop around for Detroit Locker.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
