Is it the turbo??? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-22-2013, 08:23 PM Thread Starter
Harleytruck04's Avatar
Is it the turbo???
Hey guys. After installing the bulletproof kit on my 04 it has been weak like the turbo is not spooling but it is building boost on the intake side for sure because when letting off the throttle it feeds back through the breather. It has 4" turbo back straight on it and the exhaust has no "noise" to it. It's like it's just moving air. Friday it began to get a little better and had some power back to it for about 10 miles and it got weak again. After sitting for a couple of hours it seemed to have a little power back until warm again (not overheating eot around 210*). It just doesn't make any sense to me!!!!!! HELP
Harleytruck04 is offline
post #2 of 8 Old 07-25-2013, 11:26 AM
Maybe you didn't torqued enough a hose, or the blue boot broke.
Do you have any way to check the pressure readings from the MAP and EBP?
JorgeCanek is offline
post #3 of 8 Old 07-26-2013, 08:16 PM
Sounds like turbo vanes are stuck open. Did you clean out the turbo at all while apart?
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #4 of 8 Old 08-11-2013, 01:03 PM
ps_lane01's Avatar
Quoted: 2 Post(s)
Agreed^^ sticky vanes or boost leak
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #5 of 8 Old 08-19-2013, 07:02 AM
Turbo fart, mine was really bad, boots were tight, it was coming out of filter, just cleaned my turbo (wasnt actually sticking) and its the same. I think mines worse cause PO put the K&N filter on and I dont think it muffles as much as the stock filter
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #6 of 8 Old 08-20-2013, 01:46 PM
ps_lane01's Avatar
Quoted: 2 Post(s)
If your running a tune with egr delete your gonna have some bad compressor surge. I just put mine back to stock after rebuilding turbo and swapping with a mtw wheel and it doesnt fart anymore but if i slap a tune on it, it does it all the time.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #7 of 8 Old 08-25-2013, 08:24 AM
lifted1's Avatar
Yes I definately agree with ps_lane01 ....in the fact that the 6.0l is just not really made to be altered like the 7.3. They are designed to be left alone with factory parts. Anyway it could be a variety of things, The first thing you need to do is have someone check for check engine codes. YES you may not have the light on but there may be a code or 2 stored in the computer that will assist you. At this point it could be a sieged turbo to some bad sensor. How many miles on your truck? Have you ever serviced your turbo? Have someone pull the codes and post back here!
lifted1 is offline
post #8 of 8 Old 08-25-2013, 09:34 PM
Deer Creek's Avatar
Quoted: 51 Post(s)
Mine did the same thing around 200K yanked and reconditioned the turbo and now when she fires up you can hear the turbo spool up. Sounds like a jet engine! Very inexpensive to do $10 - $20 and to be honest with you it's probably something that needs to be done every other year or so!
Ryan
Deer Creek Farm
Carthage, NC. 28327
2004 F250 4X4 6.0 Diesel "War Wagon"
SRW Crew Cab Long Bed Pushing 305,000 Miles
Running 5w-40 T6 with RevX
FICM PHP Eco Tune
Blue Spring MOD
Warren 175/30 Injectors
EGR Deleted & Studded
Dieselsite Adrenaline HPOP
Coolant Filtration System
MBRP 4" Turbo Back Straight Pipe
Bullet Proof Diesel Water Pump
Ranch Hand's Legend Front & Rear Bumpers
2" Rough Country Lift
SCT Livewire Tuner
Nitto Terra Grapler 285/75/16s
Deer Creek is offline
