Differential cover bolts - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-19-2013, 01:28 PM Thread Starter
RetiredFD's Avatar
I am going to put on the 08 Alumininum rear diff cover. Ford says the bolts are 5/16x18x1.4".
If I add a washer should I go with 1-1/2" or is 1-1/4" long enough. I want to put stainless bolts on.
What is the size of the front bolts, regular steel cover? I want to change those out to stainless also.
Anyone do this?
Thanks.
- Chris
2006 F250 CCSB Lariat
RetiredFD is offline
post #2 of 11 Old 07-19-2013, 05:12 PM Thread Starter
RetiredFD's Avatar
Maybe I should move to another forum area
- Chris
post #3 of 11 Old 07-19-2013, 07:01 PM
sucks when all you hear is crickets eh?
I just got my bolts for the rear, I went with 1-1/4 and I have washers to go with, from what I've read it should be fine. If I can get my brakes done the diff cover is next on the list, I'll let you know how it turns out.
2005 - Excursion - Eddie Bauer - 4x4
185amp DC Power Engineering alternator
BPD oil cooler and cold weather package
Updated standpipes and dummy plugs
Edge Insight CTS with fuel pressure
No more STC fitting in the HPOP
Updated fuel pressure spring
Updated turbo oil drain
Updated turbo oil feed
Sinister Coolant Filter
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
The best 6.0 advice I've ever seen...
Fishermedic is offline
post #4 of 11 Old 07-19-2013, 07:20 PM Thread Starter
RetiredFD's Avatar
Bring the truck down, I will help ya
- Chris
post #5 of 11 Old 07-20-2013, 08:52 PM Thread Starter
RetiredFD's Avatar
Any one out there
- Chris
post #6 of 11 Old 07-20-2013, 09:00 PM
usnavyad's Avatar
Feedback Score: 3 reviews
I know I've seen a post before someone use fastnal bolts for it
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #7 of 11 Old 07-20-2013, 09:14 PM Thread Starter
RetiredFD's Avatar
What size? I would like to have them before I pull the old cover off.
- Chris
post #8 of 11 Old 07-20-2013, 09:18 PM
usnavyad's Avatar
Do worry I'm here for you
08 Diff cover bolts
GPDA's other shawn
usnavyad is offline
post #9 of 11 Old 07-20-2013, 09:25 PM Thread Starter
RetiredFD's Avatar
I saw that thread. I am ok I think with the rears for he 08 cover. I am looking for the front bolts for the OEM steel cover. I guess I may just have to pull a top bolt and check it out.
- Chris
post #10 of 11 Old 08-13-2013, 04:45 PM Thread Starter
RetiredFD's Avatar
The factory front cover bolts are 3/8"-16 x 3/4"
- Chris
