Heavy vibration - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-02-2013, 07:57 AM Thread Starter
Heavy vibration
Ok guys need some help on this one I have a 2006 cclb f250 just recently I've started to notice a vibration that mainly is noticeable and gets worse about 30-?? when im on the highway everything vibrates the mirrors, door panels and its
Just getting really annoying also if im going about 5-10 mph in teaffic and go to accelerate the steering wheel shutters (shakes real bad up and down) seems to be drivetrain related. My tires were shot so I put new tires on no difference my next step is to replace the u joints and replace the center support bearing has anyone had any same issue or heard of anything like this caused from u joints and center support bearing? Thanks
Sent from AutoGuide.com App
chad388 is offline
post #2 of 4 Old 07-02-2013, 07:58 AM Thread Starter
Also the front end is tight tie rod ends, ball joints,wheel bearing etc also there is. 2.5 inch lift.
chad388 is offline
post #3 of 4 Old 08-08-2013, 05:16 AM
I have the same vibration but I don't feel it until about 60 on the highway. Did all the ujoints in the rear drive shaft and it's still there. Had the mid-ship bearing looked at and was told it was fine. Today it's in getting the entire driveshaft spun to check for balance... These things are tough to locate at times...
2004 F350 4x4 (155,000)
6.0 turbo / automatic
studded / deleted
gtmgooser is offline
post #4 of 4 Old 08-08-2013, 08:16 AM
Therabbittree's Avatar
Check all the drive shafts for play especially the slip joints and double carden joints. My '05 Excursion needed the double carden joints replaced. When it was out they had to reweld the tube I had them add slip joint grease fitting and a greaseable u joints.
Physically get under the truck and rock / shake the components.
Let us know what it ends up being.
Thanks,
Deo
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
