loud hum/grind from pass front end...NOT THE WHEEL HUB - Ford Powerstroke Diesel Forum
post #1 of 29 Old 06-28-2013, 05:51 PM Thread Starter
Strokergonebroke's Avatar
2004 psd 150k
so i have this very loud hummig/grinding coming from my front pass side.... the noise starts at 20-60mpg(tire/road noise over powers it after that).
The wheel hub is a brand new Motorcraft oem part # maching wheel hub assembly and still the noise is there.
Swapped tires around to even see if that was the problem.
Took out the locking hubs and still the noise comes in, and even in 4wd the noise is still there.
The diff case is full with diff oil and it looks good and no smell.
Any ideas here guys? I'm admitting defeat here.
I'm in the Littlerock area if anyone is local and want to see in person the problem here.
EXTRA INFO: the front pass axial as ALOT of play in it like there is suppost to be a seal or something in there right behind the hub, i can literally move it over a inch any way up/down side/side.
2004 6.0...studded,sinister coolant filter,updated turbo lines,oil cooler,fuel spring,egr delete, 6in lift, 37 military tires, looney'd and podded.
Strokergonebroke is offline
post #2 of 29 Old 06-28-2013, 06:05 PM
ZMANN's Avatar
Quoted: 1905 Post(s)
interesting
if it does it with the actual locking hubs removed
I would start with trying to turn the front drive shaft by hand to dble check
it's disengaged I would also try and turn each axleshaft by hand
that would eliminate the whole transfer case concern
and most of the front end possibilities
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #3 of 29 Old 06-28-2013, 06:06 PM
ZMANN's Avatar
ahhh i just picked up on the axle shaft deal
did this start with the new unit bearing or was it present before ?
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #4 of 29 Old 06-28-2013, 06:16 PM Thread Starter
i notice the axial play when i was replacing the hub, i took off the driver side and saw it had no play so i know theres a problem there but with it being my DD i hade no choice but to save it for another day.
i can turn both axials no problem by hand, seem smooth and trouble free.....also when in the passanger seat you can feel the vibrations from whatever it is in your feet.
i'll check tranfercase fluid level tom to make sure but me and 10+ buddies all agree its pass side its coming from.
wheel also spins with no issues at all.
like i said i truely give up at this point and accepting any help or ideas.
post #5 of 29 Old 06-28-2013, 06:19 PM
ZMANN's Avatar
you have a seal and a needle bearing in there did those get replaced ?
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #6 of 29 Old 06-28-2013, 06:22 PM
ZMANN's Avatar
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
yours is like this mine is different but if the needle bearing is new and the axle stubshaft are fine it may just be a axle u joint issue
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #7 of 29 Old 06-28-2013, 06:25 PM Thread Starter
the entire wheel hub assemble got replaced...i was told the needle bearing thats pron to go was in the wheel hub and is unservicable.
post #8 of 29 Old 06-28-2013, 06:28 PM Thread Starter
i was going to the u-joints as the problem next but honestly have no idea how to check or what to look for..... this is my first 4x4 truck,i'm more of a mustang expert until we relized it wasnt ment to have a baby in the back seat. haha
post #9 of 29 Old 06-28-2013, 06:49 PM
ZMANN's Avatar
lol
the axle-shaft is a little more involved than the hub because you need to pull the knuckle seal and reset it with a special tool to depth
I think the needle bearing is replaceable but I think it also came with your new hub
mine uses a complete different sealed bearing that is replaceable
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #10 of 29 Old 06-28-2013, 06:51 PM
ZMANN's Avatar
FYI on the needle bearing
With the hub off, we expose what this entire exercise has been about, the needle bearings, yep those non-serviceable, non-existent bearings that the dealerships apparently have no knowledge of. Hopefully you can see on this photo that there is a small amount of lubrication remaining on these bearings but they do need servicing.
If your needle bearing looks worn, you should replace it with a new bearing (Ford-C6TZ-3123A NAPA-B2110
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
