Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Drivetrain problems
Old 03-30-2008, 10:16 PM
DunesRunner08 DunesRunner08 is offline
vibration post for DunesRunner08
If anyone can help please...I tried to start a thread, but i couldn't, so here I go with this question.
2006 F250 w 6.0L in it. Mods for power are intake exhaust and programmer. I've had no issues till the past couple days. I am getting a big vibration when the engine is working up to speed. None when I'm in neutral, and it comes and goes, mainly when under load or when i let off the gas and hit it again so its reving up to catch up to get the load (if you get what I'm saying). I have no Idea what the problem is. I tried to return the program to stock and that didn't change it. Has anyone else had this? Can someone help me out?
Old 03-30-2008, 10:21 PM
Powerstrokin03 Powerstrokin03 is offline
Rebel
First it sounds like a drive line vibration when accelerating could be U-joints in the rear drive shaft. I would check that first.
Old 03-30-2008, 10:26 PM
I will do this tomorrow. now just so im not going back and forth, what else could it be if its not that?
Old 03-30-2008, 10:34 PM
95and05 95and05 is online now
allergic to hot weather
Send a message via AIM to 95and05 Send a message via MSN to 95and05
it could be anything from axels to anywhere in the drive train from the tranny or T-case to the drivelines or even rearend. need to do a little checkin and start with the easy to get to like the u joints. then post an update with as much info as possible... what you checked and how you checked it.
why couldn't you start a thread? can we help with that?
Old 03-30-2008, 10:37 PM
its said I didn't have the privledges to do so... I'll keep updating. Dumb question, I can walk out and look at the U-joints now, how can you tell if they are bad? I've done a lot of upgrading in my time, and usually dump vehicles before they break, but this is a company truck and well i'm stuck with it. lol I'm not a maintenance and upkeep guy. Im dumb when it comes to this.
Old 03-30-2008, 10:47 PM
grab the driveshaft near each end and wiggle in all directions it should not move. if you have slack at one end then that end has a bad u joint you should also watch and feel for slack in the yolks
Old 03-30-2008, 10:52 PM
posted this for DunesRunner08 to move from other thread
Old 03-30-2008, 10:53 PM
I posted this on a seperate thread for you.
Old 03-30-2008, 11:11 PM
ok. so i crawled under the truck and shook the driveline. the rear u-joint and the carrier bearing were good. the u-joint thats up near the t-case had a little movement and a rattle when i shook it. Is this most likely the problem?
Old 03-30-2008, 11:14 PM
thanks for the help 95
