Front Hub Assembly Stuck Locked In - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-20-2013, 06:00 PM Thread Starter
Mstanek589's Avatar
Recently I put my truck into 4x4 using my push button ESOF system. And it went in fine, however, when I went to take it out of 4x4 it stayed locked in. Now I have a couple of questions. The first one being; is it ok to run em locked in, if you plan on replacing anyway, or will it hurt something else, like the freaking $430 wheel bearing/hub assembly? I'm already hearing a grinding and popping noise when I'm going slow, and turning,im also getting the nice 4x4 on dry pavement hop (but that's obviously going to happen). So my second question I guess, is do you think that that grinding is in my hub assembly or if its just my auto lock hubs? What all do I need to start putting on the parts list? Any help would be helpful. Thanks in advance guys.
Mstanek589 is offline
post #2 of 3 Old 06-20-2013, 10:22 PM
Try turning the hubs manually from auto to lock at least three times, should unlock for you unless something is wrong in the hub. You can drive around with the hubs locked in without damaging anything, it just puts wear and tear on the front axel as it is spinning all the time. But if you are jumping on dry pavement, it sounds like your transfer case is still engauged as well as your hubs, which is something you should not be driving around on dry pavement with.
Phil
2005 F350, 6spd, arp studs, banks big hoss bundle, straight pipe with dual exhaust, egr delete, high idle mod, dashboss monitor, battery tender 800ma, 6.5 watt solar panel, kn cold air intake with an s&b filter, dfuser coolant filter, bds 4" lift on 325/65/18 bfg all terrains
phil_phil is offline
post #3 of 3 Old 07-09-2013, 03:44 PM Thread Starter
Mstanek589's Avatar
Ok thanks Phil. Yea it's not really hopping too much anymore, the grinding is still going on, which is starting to make me think brakes... Idk if it would stop raining around here I'd take the darn thing apart
