Removing cross shaft pin in front carrier. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-19-2013, 12:13 AM Thread Starter
RoCkfiSh363's Avatar
I'm trying to pull my axle shafts on my 05. I cannot figure out what to use to get that cross pin out of the carrier. It looks just like a circle with no hex or octagon ect. Anyone know what to use to get that bolt out?
05 EX Cab Short
8 inch Fabtech
38 inch SSRs on 17x10 Centerlines(powdercoated)
SCT Innovative tunes
Banks CAI
Offroad MBRP Stainless 4.5 " and up pipe.
Auto Meter EGT, Fuel pressure, Trans Temp, Oil temp, water temp gauges.
Blue spring , bored 3 hole banjos.
ARP Studs
OEM Ford gaskets.
EGR Delete, cooler delete.
Bulletproof stand pipes
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
Innovative 48v FICM Performance flash.
RoCkfiSh363 is offline
post #2 of 2 Old 06-20-2013, 02:25 PM Thread Starter
Haha never mind. Rookie mistake, it's a roll pin that get's pressed out once the shafts and carrier are removed from housing.
05 EX Cab Short
8 inch Fabtech
Banks CAI
ARP Studs
OEM Ford gaskets.
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
