Ball joint questions - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-14-2013, 11:07 AM Thread Starter
I have an 05 f250 psd 4x4, can anyone tell me what balljoint service tool they used to service theirs. I went to JW to get alignment done and they told me I needed a new hub assembly. I replaced the driver side hub assembly and my wife took it back, now they told her it needs adjustment sleeve and left upper balljoint. I know you can't replace one balljoint. Does anyone know if Moog balljoints are good?
Thanks any thoughts would be great.
pperchansky is offline
post #2 of 9 Old 06-14-2013, 11:27 AM
JUGGS's Avatar
Moog is very reputable as far as I know.
2005 F250 Lariat CCSB/170k mi./6sp Handshaker
Don't Worry
Dieselsite coolant filter, CAT ELC, Bulletproofed and monitored by BPD
Be Happy
SCT SF3, 4" Flo Pro, 2.5" Readylift SST, 35" GoodYear Fierce Attitude M/T's
JUGGS is offline
post #3 of 9 Old 06-14-2013, 05:25 PM Thread Starter
Thanks JUGGS
post #4 of 9 Old 06-14-2013, 05:59 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
I would choose OEM over moog but I am a bit biased. The OEM joints are non-servicable with no grease fitting and if that's a big deal then choose aftermarket.
We use the OTC master ball joint kit at work. It definitely has enough pieces to quickly do super duty balljoints. Unfortunately at this time I can't rattle off exactly which adapters you need, there are several.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 9 Old 06-14-2013, 06:01 PM
ZMANN's Avatar
Quoted: 1339 Post(s)
you can replace 1 ball joint but why ?
get serviceable joints
I like Dana / then Moog unless you want super high end units
We Miss you Ronnie
ZMANN is online now
post #6 of 9 Old 06-14-2013, 06:03 PM
ZMANN's Avatar
sinner posted as I was typing
but OEM has a serviceable unit but I do not have the part # handy
I tried to get Ford to install them on mine but they didn't have them in stock only the non serviceable units
We Miss you Ronnie
ZMANN is online now
post #7 of 9 Old 06-14-2013, 06:08 PM
Marine Raiders>Seals
najaf4life's Avatar
I have DyanTrac pro steer ball joints. If you can afford them. You can't beat them.
RYAN
03 Excursion 6.0L
BPD,WPE & other odds and ends
najaf4life is offline
post #8 of 9 Old 06-14-2013, 07:16 PM Thread Starter
Thanks Sinner, ZMANN and Ryan. I have am going to go to dealership in am and get some prices on parts. I have a question on the axel shaft seal, I hope this doesn't sound dumb but here goes. When I knock out the shaft seal will the seal still be on the shaft? If so do you hammer it off. When I install the new seal, does it go on the shaft first and then get seated into the knuckle. One more question, on the upper balljoint is there an adjustment sleeve. JW said they adjusted the tow in and that I needed an adjustment sleeve.
post #9 of 9 Old 06-17-2013, 09:34 AM Thread Starter
Update on balljoints and adjustment sleeve. I have decided to let the dealership do the work, I'm working out of town and kinda ran out of time. Going on vacation with family on Friday and towing 31ft TT from Pa to Sc. The bottom line is my family and I will be safe.
Thanks for all the input guys.
